Page 16 of 25 FirstFirst ... 678910111213141516171819202122232425 LastLast
Results 226 to 240 of 361
Thread: American Standard Champion toilet Review and comments. Rated #1 by Consumer Reports
  1. #226
    Comments by readers Reader Review's Avatar
    Jan 2006
    I have had all the same problems. Took the lid off and manually lifted the flush mechanism so that I could let it down gently, thus avoiding knocking off the gasket.
    Have since had the entire flushing mechanism replaced. The replacement parts were bought at a Plumbing supply store. It looks nothing like the original. So far all is working well.
    Shirley
  2. #227
    Jan 2006
    Three months ago, I posted an extremely negative review of our four Champion toilets, which were installed in 2004. We had repeatedly contacted the company for replacement parts, but those parts never solved the problems. I mailed a copy of that review to American Standard, and was contacted by a customer service representative. The company has redesigned the "guts" of the tank (they needed to; the old design simply didn't work!), and they shipped four replacement kits to me. The kits have been installed and, so far, are working well.
    Suggest people who have been going crazy with these toilets the past few years contact American Standard for the NEW design.
    Teresa B
  3. #228
    From what I was told... I have the new design flush valve built after 6/2007. Mine still leaks constantly. Every 10-15 mins I hear the water running as it fills back up. My water bill is through the roof!
    I still have not recieved my warranty parts that I called about 2 weeks ago.
  4. #229
    Dec 2007
    Measure the inside width side to side in inches, front to back in inches, and how far the water drops every time before it fills back up. Multiply the 3 numbers than divide by 231. The answer is approx. how many gallons you have wasted every time you hear it run. Figure how many times an hour or, even a day and figure out how much is wasted...
    You should be sending them a bill!
    Call them again and let them know how happy you are!
  5. #230
    DIY Member plumbtired's Avatar
    Jan 2008
    Portland, OR metro
    Unhappy Oh, No!!!
    I, too, posted (in Feb. and March) very positive results on this Champion toilet (have two of them) after receiving such great customer service from American Standard per the replacement flush valve assembly (replacement of the faulty tower/piston flush valve). Everything WAS (notice the emphasis upon WAS) going beautifully...until three weeks ago. Then "all Hell" broke loose in BOTH Champion toilets, within two days of each other. Now I have two (AGAIN!) defective toilets, automatically flushing or continuously running. Obviously, the replacement seals/gaskets failed at the same time. Geez, this means the seals/gaskets lasted less than four months!
    At this point, I've had it...those two toilets are, essentially, "out of here." I will take the $400 loss and invest in the highly-rated Toto toilets. I am not willing to fuss with these two poor quality American Standard Champion toilets any longer, even though American Standard continues to honor the warranty with continual seal and/or flush valve replacements. The ONLY thing I can say, in a positive light , is that I have NEVER had a clog in either of these Champion toilets, compared to constant clogs in the former Kohler toilets we had (prior to the Champions).
    So, what model of Toto has a large trap? It is the Drake? [Thanks for any advice...]
  6. #231
    Dec 2007
    The Toto Drake is one of many of them that do!
    May I suggest using the Chumpians as planters!
    They serve very well for that purpose!
    They may also provide stimulating conversation among guests as to what a good toilet is and what a bad one is.
    This conversation may prove to be theraputic
    This venting that I do is actually therapy for the times I have been burned by installing defecive Am. Std. products...
    It only happened a few times before I stopped using them... I'm no Idiot!
    But, I hold a grudge a long time!
  7. #232
    Review Terry's toilet info from his home page. Some of the decision would depend on style, but you don't have to spend a huge amount for performance. The Drake does work well, but if a different style would make your day, they have many other than the Drake.
    Personally, I like the look and lines plus ease of keeping clean the skirted models - no nooks and crannies to try to keep clean. These generally require the water supply placement to be more critical, though.
    Drake 800 grams by Veritech Video
  8. #233
    Engineer maddog's Avatar
    Aug 2006
    near San Jose, CA.
    Default leaky Champion seal
    Just got back from a 2,000+ mile trip around the South West. I know I have issues - but I took a look at the toilet each place we went. To my surprise, every toilet except 1 was an American Standard toilet (the other being a Kohler). New construction in Sedona Az had new AS toilets with the old style ballcock and plastic float ball!. Not sure if their commercial toilets are better built than their residential toilets, but they should certainly know how to make a flush seal that doesn't leak. Even with extremely hard water, the new Champion flush valves should go a lot longer than 4 months without leaking. I have soft water and have not experienced a leak with either the old flush tower or the new flush valve. I did have problems with a Mansfield flush tower leaking before replacing with a Fluidmaster flush valve. If I experience problems with the new Champion flush valve, I will certainly post back here. But so far, it's been working great. And after putting in the new flush valve, I took apart the old flush tower - what a crazy, over-complicated contraption ... a real "Rube Goldberg" device!
  9. #234
    Jan 2008
    Portland, OR metro
    Unhappy Woes with the new and "improved" flapper-style flush valve
    Yes, maddog, the problems I am currently having are with the new style (flapper style) replacement flush valve on my two Champion toilets. Like I stated, and you agreed, less than four months in SOFT water (Portland, OR area where we have "the softest water in the country") is not acceptable for the seal life of ANY flush valve/flapper seal.
    Good luck with your new Champion (Fluidmaster) replacement flush valve. I, too, was thrilled over the flush valve improvement...until a couple of weeks ago when the seals apparently failed simultaneously in both of my AS Champion toilets.
  10. #235
    If you use any of the tank type cleaners, STOP. Those can eat up the plastic and rubber parts very quickly.
  11. #236
    I just called AS again about my replacement seal. It's been over two weeks and no seal yet.
    The guy said the seal is on backorder! Well, thanks AS for letting me know this! While my POS toilet fills every 10-15 mins 24 hours a day.
    He said he's going to send me the entire flush valve. Why the heck they didn't just do that in the 1st place is beyond me.
    So anyone that's waiting on a seal needs to call AS and tell them to send you a whole new flush valve or you're gonna be waiting for a long time for the back ordered seal.
    I'm sure the city loves me now that my water bill has gone through the roof.
    I wonder what kind of reception I'd get if I took this hunk of $hit toilet out, carried in to Lowes (where I bought it) and set it on the returns counter. Ya think they'd give me a refund or store credit?
  12. #237
    DIY Member Squ1rrel's Avatar
    Dec 2007
    Texas
    Knowing Lowes? theres a chance....just rant at a manager, especially if you still have the receipt.
  13. #238
    Central Florida
    I just took a POS lawnmower back to Lowe's a week ago, 11 days out of their 90-day return period. It only took a few minutes of ranting to get them to agree to give me a store credit, and then the computer system refused -- all it would allow was a full refund. They've been pretty good to me over the years.
  14. #239
    Jan 2006
    I wish I would of read the consumer report before I bought a
    champion. I to had to get a professional plumber to change
    the mechanism. I thought I had broke it but it turns out there is no adjustment..I blame Home Depot for pushing me to this toilet..
    J Molk Fri,June 27th,2008
  15. #240
    I wonder why on terrys page he doesn't say "NOT RECCOMMENDED" for the champion toilet???
    http://www.terrylove.com/crtoilet.htm
    He says it for the briggs and I bet the briggs doesn't leak 24/7.
  1. American Standard Cadet 3 Three Toilet consumer product review
    By LaNor in forum Toilet Forum discussions
    Last Post: 02-17-2014, 12:53 PM
  2. Briggs Vacuity toilet review and comments. Rated #1 by Consumer Reports
    By superecho in forum Toilet Forum discussions
    Last Post: 09-07-2012, 02:55 PM
  3. American Standard Champion toilet Review and comments. Rated #1 by Consumer Reports
    By Reader Review in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2011, 11:09 AM
  4. Eljer Titan toilet product review, Rated #1 by Consumer Reports
    By Reader Review in forum Toilet Forum discussions
    Last Post: 04-18-2011, 06:32 PM
  5. Replies: 25
    Last Post: 12-12-2009, 09:47 AM
