Results 1 to 4 of 4
Thread: Moen Toilet Levers
    DIY Junior Member bielen's Avatar
    Jan 2014
    New Jersey
    Default Moen Toilet Levers
    Does anyone know if the Moen Toilet levers, specifically the Waterhill, will fit the Toto Soiree. It says it will work with most front-mount toilets, but there's no way to confirm when calling Moen or Toto.
    Looking inside the tank of the Toto Soiree
    It looks like it should work.
    Moen 90 series trip lever
    The Toto lever is on an angled surface, but the Moen lever should work as long as it can be bent to match the angle.
    For max reliability, the end of the arm of the lever must be above the flapper, and nearly centered so it can pull almost straight up. Hard to say if it can be bent to match up without seeing it in person or a really god photo. The hole through the tank is probably about the same, but that's not an absolute (but you can measure the Toto's hole and compare to the drawing).
  1. Moen from HD vs. Moen from Dealer
    By jm66208 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-16-2013, 02:27 PM
  2. Parts: Keyboard style levers for On-Off valves
    By geniescience in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2010, 09:21 AM
  3. In a Moen Jam need a fix
    By Keaton62 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-13-2009, 09:35 AM
  4. Grohe shower volume valves & levers
    By sharding in forum Shower & bathtub Forum & Blog
    Last Post: 05-29-2008, 01:16 PM
  5. Moen, Moen, moan . . .
    By utahtenorsax in forum Shower & bathtub Forum & Blog
    Last Post: 05-27-2006, 11:13 AM
