Results 1 to 5 of 5
Thread: Kinetico Model 60 won't draw
Hybrid View
    DIY Junior Member GaryG's Avatar
    Sep 2012
    Washington
    Default Kinetico Model 60 won't draw
    Hi,
    I have a Kinetico Model 60, which stopped drawing brine. During the brine cycle, water continues to flow to the brine tank (no suction). It won't drwa on either the normal timer or the manual regeneration.
    Here is what I have done already:
    1. disconnected brine line (confirmed there is no suction, but rather water flow from the head)
    2. blew out drain line (it was not plugged)
    3. Took Head apart
    .... confirmed gears and turbine spin freely
    .... blew air through the venturi and all the openings
    .... verified all the valves move freely
    .... confirmed check valves are in place.
    Any ideas on what to try next?
    In the base level, are there balls or pegs? The brine draw occurs about two minutes after regeneration initiates.
    Water pushes toward the brine tank during all other stages.
    It could be the control disc is worn. Have you checked the ridges?
    It was an INSIDE JOB!!!!
    Sep 2012
    Washington
    The base level has pegs. The unit is almost new. The control disc doesn't look worn.
    Gary
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Check the drain flow controller for the debris. Hold the venturi up to the light to make sure no blockage is present.
    Sep 2012
    Washington
    Hi,
    Checked the drain flow controller and it was clear. Also checked the venturi, which was also clear.
    Any other ideas?
    Gary
  1. kinetico model 60
    By ChadI in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-24-2011, 08:39 AM
  2. Kinetico Model no. 30 Problems
    By Mobster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-28-2009, 01:41 PM
  3. kinetico model 30 help
    By hattrick37 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-26-2009, 06:55 AM
  4. kinetico model 30 help
    By hattrick37 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  5. Kinetico model 60
    By ErikM in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2009, 09:58 AM
