DOCSCANTLIN
Gentlemen:
Thank you so very much for all your input. Yes, it seems I should have checked the pressure but my gauge was inoperative and it seemed the pressure through my faucets was "fine". Plus the faucets through the softener were same as the faucet bypassing the softener. I didn't check softener drain flow, thinking the water coming out of both the drain and brine would skew the reading. Of course, any of you experienced guys would have simply looked at the flow and ascertained low flow. 1 pint per minute has got to look different than 1 gpm. So I apologize for leading you all on, possibly, a wild goose chase. I am picking up a fitting to install a new gauge, am getting ready for a show so can't install until Sunday. I will report back. Thanks again. Now, to learn all about switches, pressures, tanks, etc. My well (and tank/switch) is 10 years old with the pump in the ground.
Kind regards, Doc
Thanks again. I have learned much from you all!
Kind regards, Doc
