Results 1 to 7 of 7
Thread: Plumbing Clean out
    DIY Junior Member Manseau's Avatar
    Sep 2012
    thunder bay
    Default Plumbing Clean out
    Can this be plumbed as the picture shows or can someone give me some advice on a different way.
    Thank You
    Nov 2010
    Maine
    The clean out is ok but I don't like the double wye on a washer. I'd rather see the washer come into the vertical below that other line if possible.
    IF that is REALLY a vent, then the washer has to connect with a sanitary tee, while the other side MAY connect with a "Y", assuming it is independently vented.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Plus the washer drain needs to be 2" pipe with vent off after the p trap
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    in ontario 1-1/2" is fine for washer drain..depending on the distance to p-trap for washer you can stack vent with the vent you are tieing into as long as there is no discharge above and you connect to "vent" using a T
    Many of the newer WM pump water MUCH faster than the older ones, and while redoing things, you will be MUCH happier in the long run if you use 2".
    quote; in ontario 1-1/2" is fine for washer drain
    You are confusing a "minimum standard" with one that is adequate under ALL conditions. In the wall washer boxes ALL have a 2" drain outlet for a reason. The washer trap does NOT need an individual vent, IF that riser is truly a vent and not a drain from upper floor fixtures. Another thing we do not know is what the right hand pipe that "goes into the ground" does or is for.
  1. Water Well Clean Out?
    By Michael Holmes in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-20-2011, 05:05 PM
  2. Clean-Out Location
    By KULTULZ in forum Plumbing Forum Discussion & Blog
    Last Post: 11-03-2009, 07:17 AM
  3. Should I try to clean the A/C coils myself?
    By riker1384 in forum HVAC Heating & Cooling
    Last Post: 11-11-2008, 05:44 AM
  4. New Tub Problem- won't get clean!
    By Onemoretime in forum Shower & bathtub Forum & Blog
    Last Post: 10-03-2007, 12:23 PM
  5. clean out plug
    By rihokie25 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-13-2005, 02:12 PM
