Results 1 to 6 of 6
Thread: How to install CSV and Pressure with my setup?
    DIY Junior Member SSmith's Avatar
    Sep 2012
    Alberta, Canada
    Default How to install CSV and Pressure with my setup?
    Today we had a brief power outage and now I have no water and the Gundfos CU301 is beeping....
    The pump is ok as I moved the wires from the pump to the power and we have lots of water that way.....
    Anyways I think it is time for me to switch to the CSV and Pressure switch method.....
    I am enclosing a few pictures of my setup now, and would appreciate it if someone could advise me where I need to install the CSV and pressure switch, as well as the exact parts I need to procure....
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    It's quite simple but let's hear it from the expert/inventor, Kerry Austin! I'm sure he'll respond on or before Tuesday!
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Feb 2011
    NW Ontario, Canada
    Not Kerry, Cary, AKA valveman.
    Sep 2012
    Alberta, Canada
    Thanks guys.....
    Is there anywhere in Canada that supplies the valves?
    Feb 2011
    NW Ontario, Canada
    There is not a comprehensive list of dealers or distributors In Canada. That said, Ingram is in BC.
    http://www.wellrehabilitation.ca/ind...le-stop-valves
    Valveman might be able to give you some referrals.
    Jan 2008
    Virginia Beach, VA
    A pside-kick http://www.cyclestopvalves.com/products.html is a kit (with instructions) that replaces your present VFD computer and sensor. Check it out or call Cycle Stop Valves @ 800-652-0207 they will be happy to assist you on Tuesday.
    Porky Cutter, MGWC
  1. New Setup installed today and still want more pressure... Myer HJ75D
    By larryruest in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-20-2011, 06:34 PM
  2. Pressure Regulator install Q
    By BrianPlumBrian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-04-2007, 06:04 AM
  3. Where to install a pressure regulator
    By Guest in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-25-2006, 04:14 AM
  4. Where to install pressure regulator?
    By Vitaliy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-01-2005, 08:13 PM
  5. can I install a second pressure tank?
    By cselwitz in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-25-2005, 10:14 AM
