Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 88
Thread: Leaking Kitchen Aid Fridge Freezer (model KBF S25EVMS3) - plugged drain line.
  1. #46
    DIY Junior Member FreedMiester's Avatar
    Nov 2013
    Deerfield nh
    Quote Originally Posted by johnfrwhipple View Post
    If this is a common problem then I am going to start informing the builders I work with that I have another plan. My wife this morning has green lighted operation Fridge drain line!
    JW
    I have the same Kitchenaide, with the same problem. If you unplug the unit and take everything out of the freezer drawer, you can then remove the basket and plastic drawer insert. In back of where the drawer is (Yes, I wish tho whole freezer door would come off, but I couldn't figure out an easy way to do that, so this is awkward to reach) is a metal? panel with vents in the bottom. Behind this is the evaporator coil, and in the center is a drain hole that connects to a short rubber tube with a "fish mouth" end, that exits into the pan underneath. The fish mouth is supposed to keep cold air from leaking out, but open to allow water to drain. It is clogged with ice. There may be a heated wire that is supposed to melt the ice (i don't remember). I pulled that panel out and used a hair dryer to clear the ice from the drain and it took another 9-10 months to clog up with ice again. Now that it is clogged again, I plane to pull the fridge forward, remove the hardboard panel from the the back of the fridge and try to clear the drain from there (it has to be easier). I might cut some of the "fish mouth" off to let it drain easier...
  2. #47
    Feb 2005
    Omaha, NE
    Quote Originally Posted by SteveW View Post
    Very disappointing, John!
    If this is your condensate drain line freezing up, and there is no debris causing this to happen, I have read on some of the appliance forums that some techs will wrap copper wire around the defrost coils and run the wire down the drain a little ways - that way every time the fridge does a defrost cycle it melts any ice build up. I think I have seen some actual repair kits that use this principle in one of the appliance repair parts sites.
    Just resurrecting this post. For some fridge models there is an retrofit kit from appliance parts stores that includes a wire that goes from the defrost coil to the condensate drain so that any ice gets thawed every defrost cycle.
  3. #48
    Jul 2009
    North Vancouver, BC
    The fridge is repaired again for a second time.
    With the last two bills averaged out this crappy fridge is costing me $18.00 PER MONTH in maintenance. What a joke.
    JW
    NEWS UPDATE
    KITCHEN AID HAS REDESIGNED THE DRAIN TUBE - PLEASE JUMP TO PAGE 5 TO FIND OUT MORE
  4. #49
    Jul 2009
    North Vancouver, BC
    With the last two bills averaged out this crappy fridge is costing me $18.00 a month in maintenance. What a joke.
    JW
  5. #50
    Here is the tech bulletin. Your appliance service person should know about it.Repeat failures is not exceptable (at least not in our shop). You may need to find another repair person.
    PDF file to big to attach I pasted relivent page without the picture
    ® Registered trademark of Whirlpool, U.S.A., KitchenAid, U.S.A., Jenn-Air, U.S.A., or Maytag Properties, LLC or its related compa
    ®MAGIC CHEF is a registered trademark of CNA International, used under license. © 2013 All rights reserved.
    For Immediate Attention of Your Service Department TECHNICAL
    SERVICE
    POINTER
    Technical Service Pointer #: W10632338
    Action Required: Informational/Mandatory
    Release Date: August, 2013
     Refrige
    Page 1
    Brands Affected
    ALL POINTERS ONLINE:
    https://www.servicematters.com/
    To receive pointers by email, or to edit
    or delete a current email address, go
    to https://www.servicebench.com/
    Amana, Jenn-Air, KitchenAid, May
    And Whirlpool Refrigerators.
    Models:
    See attached pages.
    Serial Numbers: All
    Concern:
    Ice build up on bottom of freezer.
    Defrost water does not drain.
    Duck bill check valve plugged.
    Correction:
    A “P Trap” drain tube kit is now available for the
    models listed on the attached sheets. If the new
    design “P Trap”, see figure 1, has not already been
    installed, Order and install kit part number
    W10619951. Follow the detailed instructions supplied
    with the kit.
    Politicians are like diapers. You need to change them often……for the same reason.
  6. #51
    DIY Junior Member asbruckman's Avatar
    Dec 2013
    Atlanta, GA
    We have the same fridge and the exact same problem.
    My best guess about what is happening is that it's really easy for the middle freezer drawer to get bent a bit.
    That makes it hard to close the freezer properly. Whenever it's left a bit ajar, stuff melts.
    And the water then creates a sheet of ice on the bottom of the freezer.
    And the sheet of ice makes it impossible to close at all.
    We're now removing the sheet of ice twice a week.
    Thinking about trying to bend the bins back in shape, but can't figure out
    how they're supposed to go. I found this thread while looking for a picture
    of what the middle rack is supposed to look like--where are the wheels supposed
    to ride? The two sides are bent differently. Just removing the middle
    freezer rack might help possibly....
    It's driving me particularly crazy because my DH is always asking "Who left the freezer open??!"
    And my answer is "It's @#$# impossible to close right, even if you're paying attention, for an adult.
    The kids have no hope."
    All advice appreciated!
  7. #52
    Jul 2009
    North Vancouver, BC
    Hi ASBRUCKMAN
    I think the fridge design is just a piece of crap. I hooked up some soft copper pipe to a shop vaccum to help clean the grills on the bottom. The repair man last time told my wife that this problem is so common with this fridge. He also told my wife that the fridge had to be pulled off the wall for better circulation or something. Our fridge is 4" off the mark we set it too and looks horrible.
    When I finally install my hardwood floors I'm installing a linear shower and waterproof completely under the fridge. We stopped using the water line and hate this fridge. We thought it would be a great one. Man where we wrong.
    Sorry you are having problems. Not sure what to say other than enjoy the repair man visits. This Kitchen Aid Freezer will cost me more in repairs and drain modifications than it cost new in a short time I'm sure.
    You think a brand new fridge would be able to last at least 3 years before falling apart.
  8. #53
    come on guys replace that duckbill with http://www.reliableparts.com/product...r-Parts-461376 I know the original design was junk but there is a fix.
  9. #54
    Jul 2009
    North Vancouver, BC
    IS that part OK for the Leaking Fridge from Kitchen Aid?
    I'm sure the repair man is happy coming every year and billing me. He did not mention this after market piece. Speaking of piece - this fridge is a piece of shit! LOL
    I did not know asking for a fridge that does not cause water damage to my flooring was a question I should have asked.
  10. #55
    Jul 2009
    North Vancouver, BC
  11. #56
    Jul 2009
    North Vancouver, BC
    Default Getting service for a leaking Kitchen Aid Fridge Freezer.
    So I posted the view count on Kitchen Aid's FaceBook wall and they asked me for my phone number and some info on the shitty fridge. Serial number etc. Three year back when I did the same no one called. No one asked me any info - nothing.
    Now three years at 22,000 plus views later - maybe someone at kitchen Aid will tells us how to fix this leaking fridge of theirs. Brutal the customer service. Lets see how long they take to call me and suggest a repair. I wonder what that will cost me?
  12. #57
    Jul 2009
    North Vancouver, BC
    Default 70 people per day looking for help Re: Leaking Kitchen Aid Fridge Freezer
    It appears that more and more people are looking for help with their leaking Kitchen Aid Fridge. This last ten days saw 700 people view this thread! Insane.
    What a testimonial to a piece of shit fridge I bought. So many people in the same boat. I wonder how many thousands of dollars are spend every week keeping a simple fridge working the way it should.
    Kitchen Aid Canada told me ten days ago someone would call me. Not a word. Not an email. Not a phone call.
    I guess if your Kitchen Aid you just ignore the exposure and hope it goes away…..
  13. #58
    DIY Junior Member Svendsen1's Avatar
    Jan 2014
    Huntsville, Al
    So I just finished "fixing" this problem this morning on my 2 year old Kitchen Aid fridge. Here's what I did. I pulled the fridge out and removed the hardboard back off the bottom portion of the fridge. I located the rubber fish eye drain tube and removed it and cleaned it out. It was sticky and clogged with food particles and dust from the past 2 years. (When that rubber piece clogs, the water that is melted from the defrost cycle backs up to the top of the drain that is located in the freezer and ends up freezing. ) I reattached the rubber drain tube, put the hardboard back on, and pushed the fridge back into place. I then took the freezer door off, as well as all the baskets to gain access to the back panel inside the freezer. I used a hair dryer to get the majority of the ice thawed covering the fins of the coil. I then boiled some water and using a syringe, concentrated the hot water in the center portion of the pan underneath the condenser pan to melt the ice that had frozen inside the drain that leads to the pan in the bottom rear part of the fridge. There's no need to remove the panel at the back of the freezer as long as you can get a turkey baster or syringe to shoot hot water in the center portion of one of the vents on the panel. The problem stems from the rubber drain piece near the compressor, so since there is a p- trap fix available, I was wondering if anyone had installed one yet and can comment on how it's holding up? Because I'm sure mine will clog again within the next 2 years... Im just glad I was able to avoid a service charge...
  14. #59
    Jul 2009
    North Vancouver, BC
    Thank you for your helpful post. I wish I had the time and the skill set to do this repair myself.
    Never had much luck with appliance repairs - I specialize in showers.
    Is Kitchen Aid going to pay you for your time? I doubt it. Sad that each fridge requires all this repair time and that the fridge was so poorly designed that 1,000's of people are having problems. I wonder how much damage these Leaking Kitchen Aid Fridges have caused over the years...
  15. #60
    Jan 2014
    Huntsville, Al
    I appreciate you starting this thread. I wouldn't have known what a common problem this was on such an expensive fridge had you not posted the issue you were having. Like you, I also have hardwood floors in my kitchen. By luck I guess, I happened to be in the kitchen near the fridge at the same time it decided to start leaking for the first time. I was fortunate it didn't damage my floor. I sure wish kitchen aid would pay me for my time to fix this ridiculous problem. I doubt they will though.
  1. Top Freezer working, Fridge is failing
    By thegallery in forum HVAC Heating & Cooling
    Last Post: 08-31-2011, 05:03 AM
  2. Add a drain line for a kitchen sink to an existing drain line for a washing machine?
    By Loflow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2011, 05:49 AM
  3. Kohler toilet has explodes waste everywhere, main line plugged.
    By Kim3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-24-2011, 05:41 AM
  4. Tapping Into Kitchen Fridge Line
    By bobh in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-04-2005, 08:24 AM
  5. Sewer/main line is plugged
    By jhelmich in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2005, 11:50 AM
