Results 1 to 15 of 88
Thread: Leaking Kitchen Aid Fridge Freezer (model KBF S25EVMS3) - plugged drain line.
Threaded View
  1. #15
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by viclee1117 View Post
    I have the same problem and its very fustrating and I have woods floors also. How did you turn off the water? I do not want to use it anymore cause when the ice cubes fall on he bottom (which is all the time) they melt and water literally pours onto the floor so I would rather not even use the ice maker anymore.
    We thought it was ice at first as well but it was the crappy fridge. You need to back off the levelling feet in the front and roll the fridge out. The turn off the water supply. If you are lucky the shut off for the water is somewhere else other than behind the fridge - look for an access panel somewhere close to the fridge first before moving the fridge out.
    NEWS UPDATE
    KITCHEN AID HAS REDESIGNED THE DRAIN TUBE - PLEASE JUMP TO PAGE 5 TO FIND OUT MORE
  1. Top Freezer working, Fridge is failing
    By thegallery in forum HVAC Heating & Cooling
    Last Post: 08-31-2011, 05:03 AM
  2. Add a drain line for a kitchen sink to an existing drain line for a washing machine?
    By Loflow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2011, 05:49 AM
  3. Kohler toilet has explodes waste everywhere, main line plugged.
    By Kim3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-24-2011, 05:41 AM
  4. Tapping Into Kitchen Fridge Line
    By bobh in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-04-2005, 08:24 AM
  5. Sewer/main line is plugged
    By jhelmich in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2005, 11:50 AM
