JasonT
Hi all,
I'm currently trying to install a tub with a roman faucet. The faucet's rough-in kit has already been installed onto the tub deck of the tub and the hot and cold has been soldered. I've also roughed in the main supply lines.
When I install the tub, I'm going to have limited space to allow me to solder the copper connection between the main supply lines to the hot/cold of the faucets.
I watched one episode of holmes on homes and I swear I saw the plumber use a braided hose to connect the supply to the roman tub faucet.
The question I have is can I do that? I spoke to a plumber at Homedepot and they said copper is still the best. I will have access to that area in the future so I can always replace the braided hose every 10 yrs or so.
I went to Homedepot and all they had were hoses used for normal sink faucets. Understanding that sink faucets have a lower flow rate than roman tubs, do you know if I can just use those standard braided sink faucet hoses to connect to the roman tub faucets? Would this limit the flow that my faucet will get? Basically I'll have 1/2 inch copper to a 1/2 to 3/8 shutoff valve. Then use the standard 3/8 braided hose to the roman tub rough-in kit. I'll have to solder a threaded fitting onto the roughin kit copper line to allow the hose to connect to it.
Thanks in advance!
Thanks in advance!
