Thread: Roman Tub Faucet rough-in kit connection to water supply
    DIY Junior Member JasonT's Avatar
    Aug 2012
    Mississauga, ON
    Default Roman Tub Faucet rough-in kit connection to water supply
    Hi all,
    I'm currently trying to install a tub with a roman faucet. The faucet's rough-in kit has already been installed onto the tub deck of the tub and the hot and cold has been soldered. I've also roughed in the main supply lines.
    When I install the tub, I'm going to have limited space to allow me to solder the copper connection between the main supply lines to the hot/cold of the faucets.
    I watched one episode of holmes on homes and I swear I saw the plumber use a braided hose to connect the supply to the roman tub faucet.
    The question I have is can I do that? I spoke to a plumber at Homedepot and they said copper is still the best. I will have access to that area in the future so I can always replace the braided hose every 10 yrs or so.
    I went to Homedepot and all they had were hoses used for normal sink faucets. Understanding that sink faucets have a lower flow rate than roman tubs, do you know if I can just use those standard braided sink faucet hoses to connect to the roman tub faucets? Would this limit the flow that my faucet will get? Basically I'll have 1/2 inch copper to a 1/2 to 3/8 shutoff valve. Then use the standard 3/8 braided hose to the roman tub rough-in kit. I'll have to solder a threaded fitting onto the roughin kit copper line to allow the hose to connect to it.
    Thanks in advance!
    Jul 2009
    North Vancouver, BC
    Would that not take forever to fill the tub?
    JW
    Use 3/4" mip x 1/2" solder adapters and use 3/4" water heater connection hoses.
  1. Rigid faucet supply line connection
    By mookie3333 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-13-2011, 04:40 AM
  2. Water Supply Connection for House and Irrigation
    By jasontf in forum Plumbing Forum Discussion & Blog
    Last Post: 06-02-2011, 10:00 AM
  3. Rough in for Roman tub - basic water connection to valves
    By JThiessen in forum Plumbing Forum Discussion & Blog
    Last Post: 03-04-2009, 07:35 AM
  4. Need help with Moen roman tub faucet rough-in
    By rmoorman in forum Plumbing Forum Discussion & Blog
    Last Post: 06-24-2008, 07:36 AM
  5. Need help with Moen roman faucet rough-in
    By rmoorman in forum Remodel Forum & Blog
    Last Post: 06-21-2008, 07:09 AM
