Results 1 to 3 of 3
Thread: Roof Exhast Vent Recommendations
    DIY Member coopns's Avatar
    Sep 2006
    Massachusetts
    Default Roof Exhast Vent Recommendations
    I have a Panosonic fan and getting the roof re shingled. I want to exhast the fan out through the roof. Any recommendations for roof vents for it? I think it needs to be insulated right?
    The ductwork to the roof vent should be insulated and should have a good damper. When I had mine done, I picked up the insulated duct and roof jack at Grainger, but I'm sure you can find them elsewhere.
    The installation instructions should give you a good idea of what's needed. Hopefully, the roofers will install it properly!
    DIY Junior Member john_combs's Avatar
    Sep 2012
    Ontario
    Hi,
    It is well known that the vent should have damper and a one that works well. I had the same issue, but when advised with residential roofing contractors I was promised it would be solved. And it has, they have installed it perfectly.
    That is why it is highly important to hire experts.
  1. Water test w/ lead roof vent flashing (aka roof jack) causes indoor shower
    By DavidTu in forum Plumbing Forum Discussion & Blog
    Last Post: 01-31-2011, 08:24 AM
  2. No main vent out roof?
    By doodle1 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-29-2009, 05:32 PM
  3. #Water in roof vent
    By luvtoliv in forum Plumbing Forum Discussion & Blog
    Last Post: 11-28-2008, 12:46 PM
  4. roof vent
    By jsmith6752 in forum Remodel Forum & Blog
    Last Post: 02-24-2008, 08:58 PM
  5. Roof Vent Pipe, Help Please
    By DavidD in forum Plumbing Forum Discussion & Blog
    Last Post: 07-19-2007, 05:46 PM
