Results 1 to 3 of 3
Thread: ABS Trap Arm to ABS or PVC P-Trap?
    DIY Junior Member bucky's Avatar
    Feb 2011
    Minnesota
    Default ABS Trap Arm to ABS or PVC P-Trap?
    If the trap arm is ABS what would be the best type of p-trap to use? (Needs to be to residential plumbing code.)
    We buy PVC traps that come with ABS trap adapters. My options at a plumbing supply are much better then the hardware stores.
    Nov 2010
    Maine
    An ABS trap adapter (desanko) and from there you can go chrome, rough brass, pvc or whatever you can find
  1. P-Trap into floor drain? Or is that an S-Trap? (and not good)
    By bretm1 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-22-2011, 07:19 AM
  2. Lav trap on larger trap arm: actual problem?
    By dave148 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-07-2008, 07:34 AM
  3. Bathroom sink p trap or t trap
    By ksdad in forum Plumbing Forum Discussion & Blog
    Last Post: 04-19-2007, 06:36 AM
  4. Replace S-trap with P-trap or chicago loop?
    By staceyneil in forum Plumbing Forum Discussion & Blog
    Last Post: 03-05-2007, 08:06 AM
  5. Vanity sink trap - can I use 90's after the trap?
    By chassis in forum Plumbing Forum Discussion & Blog
    Last Post: 01-16-2006, 06:40 PM
