Results 1 to 4 of 4
Thread: my sink spits
    DIY Junior Member BenE's Avatar
    Sep 2012
    Marquette, MI
    Default my sink spits
    second floor laundry is next to a bathroom. Got a new LG washer in the spring, just noticed that the sink
    faucet spits like the water was turned on and off, except it wasn't. (have private well and septic) Today
    heard the washer make two brief "gag" sounds about 5 minutes after starting. Went in the adjacent bathroom
    and the faucet spit water and air when I turned it on. Could my roof stack be clogged somehow, or is there
    a more logical explanation? Our previous 20yr old washer never made a peep, except when the tub was out of
    balance and the buzzer could be heard from the next township.
    appreciate any help.
    BenE
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    You are running out of water from your well tank,
    you need a plumber or well driller to check out your system,
    before you possible run out of water, it could be problem with pressure tank, well pump, or water level in well
    dropping below the pump pickup,
    the washer is drawing the tank down causing air in the pipes
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Obviously, unless your water and drain systems are connected together, there is NO possibility that a clogged vent, or ANYTHING ELSE, will cause a problem with the faucet's water. You have an entirely different problem and the only way to do a proper diagnosis is to be there and do our own testing.
    Feb 2011
    NW Ontario, Canada
    As hj said, the sewer should most certainly not be connected to the well pump so unrelated.
    You need to describe your well and pump system. Is it a bladder or hydro-pneumatic tank? Deep or shallow well pump? Jet or submersible? Air injection water treatment? Air is getting into the system either deliberately or not. If deliberately, then the AVC or air separator might not be working.
    Yesterday my wife had two watering hoses on the go when the timers for the soakers came on. The combined draw was more than the pump could keep up with and the pressure dropped well below the kick-in setting. As a result, the level in the hydro-pneumatic tank dropped low enough that the air escaped into the line causing air to spurt out of the hoses. The AVC on the tank would normally bleed off excess air but it does so at a slow rate and it was overwhelmed by the sudden drop in level.
  1. p-trap location Changing from wall hung sink to vanity sink
    By k9mlxj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2011, 04:46 PM
  2. Looking for Similar Sink Kohler Wading Pool Purist - OR the thinest sink you know!
    By Wally3433 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-23-2011, 07:38 PM
  3. Cost to install pedestal sink vs. cabinet sink in new construction
    By lousygolfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2007, 12:04 PM
  4. Mysterious black hose connected from wall under my bathroom sink to the sink drainpip
    By joe pipe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2006, 08:20 PM
  5. sink spits & makes noise when toliet flushed
    By mr.noclue in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-30-2005, 07:35 PM
