Thread: Taco pump 006-BC4
    DIY Junior Member emshamrell's Avatar
    Aug 2012
    Vancouver, WA
    Default Taco pump 006-BC4
    Hi
    Just had a Taco recirc pump with timer installed , finally after 9 years we have hot water quickly on the second story of our home. My concern is the pump housing is so HOT. It is much hotter than the hot water line leading into the pump. I cannot touch it for more than 2 seconds. Is this a fire hazard? Yes i asked the plumber who installed and he said they tend to run hot. Am i over concerned?
    Thanks for your help
    Nov 2010
    Maine
    Yes, they run hot. Yes, you are overconcerned.
    Have you ever tried to set fire to paper with hot water? Actually, you can boil water over a campfire in a paper cup, but not a stryofoam one. The pump CANNOT get over 212 degrees, if even that hot, as long as there is water in the pump.
  1. Taco 006 BC4 Circulator pump running 24/7?
    By scottall in forum Water Heater Forum, Tanks
    Last Post: 03-18-2010, 07:42 AM
  2. Taco Flo check circulator pump
    By MarkHash in forum HVAC Heating & Cooling
    Last Post: 10-04-2007, 08:23 PM
  3. How to pick right size taco pump
    By JOE1934 in forum HVAC Heating & Cooling
    Last Post: 06-07-2007, 05:38 AM
  4. Taco 003 Hot Water Circulator Pump Runs Hot!
    By gplumb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-24-2007, 05:30 PM
  5. Taco Ciruclation pump is whining
    By DIYMike in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-24-2005, 10:51 AM
