Results 1 to 4 of 4
Thread: lost power to Toro Rain Sensor TWRS - help?
    DIY Junior Member
    Feb 2010
    CT
    Default lost power to Toro Rain Sensor TWRS - help?
    Been using a Toro Rain Sensor TWRS connected to my Toro Vision II controller for few years now.
    We had to turn off the breaker panel today to install a new breaker for my solar arrays and when we turned it back on the power to the sensor seems gone. (At least I think this was the process as I recall the lights on the sensor ON before we turned the breaker OFF --- I did notice the sensor was OFF later in day hours after the breaker had been turned back ON.) No lights on sensor... I checked wiring to controller... nothing changed....... The controller is fine however.
    I notice the controller has 2 fuses but figure it may be for the controller.
    Not sure why the sensor lost power...
    Thoughts?
    It could also have an internal circuit breaker that has to be reset. The battery should have maintained all the settings while the power was off.
    DIY Junior Member
    Feb 2010
    CT
    To my knowledge there is no battery (or internal breaker) on the TWRS.... only the remote rain wireless sensor outside.
    Just seems coicendental that we noticed it not on afer we switch the breakers back on yet the control panel that it is wired to has power.
    DIY Junior Member
    Feb 2010
    CT
    So nobody loses sleep.... seems the electrician loosened a wire from the controller to the transformer when installing a line t the breaker box..
    Once re-attached all worked fine.
  1. lost one phase of 200 amp service panel, power company says they are providing fully
    By dweller in forum Electrical Forum discussion & Blog
    Last Post: 01-15-2012, 03:20 PM
  2. Virtual Rain Sensor
    By reskin in forum Irrigation / Sprinkler Forum
    Last Post: 06-22-2011, 09:09 AM
  3. Possible Problems With Rain Sensor
    By UCFAdam in forum Irrigation / Sprinkler Forum
    Last Post: 07-28-2008, 01:32 PM
  4. Lost power to 2nd floor on siding installation
    By rjsob in forum Electrical Forum discussion & Blog
    Last Post: 07-02-2008, 06:51 AM
  5. 2 Controllers - Rain Sensor?
    By eggsquisit in forum Irrigation / Sprinkler Forum
    Last Post: 08-22-2007, 01:03 PM
