Results 1 to 8 of 8
Thread: Pump fails to come on occasionally
    DIY Junior Member country kid's Avatar
    Jul 2010
    Eastern Oregon
    Default Pump fails to come on occasionally
    Control box humms and the pressure gauge is registering 0. Tap the control box and it starts pumping or if the circuit breaker is switched off and on it will kick on. Not a user of multi meter. Can run for a couple of days and no problem or run a couple of cycles and happen again. Pump is 240' deep.
    Thanks for any clues.
    Feb 2011
    NW Ontario, Canada
    Sounds like a bad control box. Replace it.
    Moderator valveman's Avatar
    Mar 2006
    Probably have a bad starting capacitor and starting relay in the control box. Could also have burned points in the pressure switch. Your motor could also be damaged and tripping the overload. Burned motor and pressure switch along with bad start cap and start relay are caused by “starting too much”, also called “cycling”. Just like we know smoking will give you lung cancer, we also know cycling is the number one killer of pump systems. And although there is no cure for cancer yet, there is a cure for cycling.
    Jul 2010
    Eastern Oregon
    Electrician out this afternoon be back in a couple of days, has to order a part for control box. Says Burned contacts which is not to unheard of. Thank you all for the replies. We shall see if that is the end of the saga!!!
    Feb 2011
    NW Ontario, Canada
    Your average control box new is around $50 - $60. Less than what it cost to pay someone to rebuild the old one, plus you can have the water back on the same day.
    Jul 2010
    Eastern Oregon
    Franklin 5hp on E-Bay for $276 is the least expensive I have located!
    Feb 2011
    NW Ontario, Canada
    Sorry, I was quoting for a 1HP. Not many 5HP pumps around here.
    Jul 2010
    Eastern Oregon
    no problem. Did not mean to be harsh! One quote was $550 and that made my hair stand up. Thanks for all the replies.
  1. Heat Pump Occasionally Emits Cold Air
    By Meg in forum HVAC Heating & Cooling
    Last Post: 12-29-2011, 11:22 AM
  2. Deep well pump repeatedly fails to kick in
    By myak in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-17-2011, 10:39 AM
  3. It Never Fails
    By seaneys in forum Remodel Forum & Blog
    Last Post: 08-27-2007, 08:57 PM
  4. Handle slips occasionally on new toilet.
    By hawksnest in forum Toilet Forum discussions
    Last Post: 01-05-2007, 05:40 PM
  5. Replies: 1
    Last Post: 03-27-2005, 08:12 AM
