Results 1 to 2 of 2
Thread: Could Not Tighten Shower Drain Nut W/Wrench....??
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Could Not Tighten Shower Drain Nut W/Wrench....??
    The Story:
    We were installing a 48" shower stall over a tight crawl space. We set it in mortar before placing the shower drain kit into the base.
    We had to install the drain kit after the base was installed. There was limited access to tighten the nut that tightens the rubber washer to the base of the shower.
    What I did was placed a thick bead of silicone around the drain opening and set the drain piece into the silicone. I was then able to get below the shower and hand tighten the nut up to the bottom of the shower (but could not put a wrench on it).
    The shower is in a solid bed of mortar. My question is will this silicone/hand tighten method work?
    Bill
    Edit: I know this sounds like a goofy thing to have done (and it was), but we needed the mortar to set up for the following day and could not get to a store for the drain kit. Finally, we thought we would be able to get a wrench on the nut after it was installed, but the wrench we had did not fit. So, the rest of the subfloor was installed after it was hand-tightened.
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Jan 2008
    The best answer we could give is "maybe".
    The drain should have been installed before the pan was set.
  1. Help! Kitchen sink lock nut on drain flange won't tighten!
    By LadyFixer in forum Plumbing Forum Discussion & Blog
    Last Post: 06-18-2011, 09:18 AM
  2. How to tighten a shower head swivel?
    By geepondy in forum Plumbing Forum Discussion & Blog
    Last Post: 01-07-2011, 07:32 PM
  3. What *wrench* fits for a Kohler Sink Drain
    By chefwong in forum Plumbing Forum Discussion & Blog
    Last Post: 09-17-2006, 06:38 AM
  4. Hand tighten or with wrench
    By JDC in forum Shower & bathtub Forum & Blog
    Last Post: 07-03-2006, 09:38 PM
  5. New Shower Arm will not tighten
    By clineberry9702 in forum Shower & bathtub Forum & Blog
    Last Post: 04-05-2005, 10:10 AM
