Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: Vibration and knocking / shaking from submersible well pump system
  1. #16
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    A lot of times adding air to a tank with a ruptured diaphram or bladder results in the system being loaded with all the sediment that has accumulated in the tank over the years.
  2. #17
    DIY Junior Member cpowers's Avatar
    Aug 2012
    indiana
    Sorry about the delay, i actually replaced everything on 11/2/13. I did not get the csv due to time constraints. i did upgrade to a 44 gallon tank. I was unable to reuse any old parts except the gauge, all was frozen together and or wrong size. The stand pipe for the pressure switch was clean. I adjusted the switch so far the spring was not being touched, i could not make it closer than 30 psi swing, so i replaced it.
    The new system which runs 40/60 has much better pressure and runs far less. Even with the larger tank it only takes about 55 seconds to fill from 40 to 60 psi. I see a csv in my future. I still need to recover from the cost of brass! The water hammer is significantly reduced as well.
    I also took advantage of this time and re hung my well pipe. I chose to use pipe insulation and 1.5" plastic hangers. I can barely hear the hum now, and can no longer hear it upstairs at all.
    Thanks for all your help.
    Chris
  3. #18
    Sep 2013
    Quote Originally Posted by cpowers View Post
    Did you install a new pump?
  4. #19
    Aug 2012
    indiana
    No. I guess not everything.
  5. #20
    Apr 2012
    ct
    Should have put in a larger tank. Fewer and longer pump cycles equals extended motor life.
  6. #21
    Feb 2011
    NW Ontario, Canada
    Better sooner than later.
  7. #22
    Aug 2012
    indiana
    I went from a a 20 gal to 44. Tried to get info from original installer, but no luck.
  1. Replacing old submersible pump/pressurizing tank vs constant pressure system
    By hannahw in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-09-2012, 06:48 PM
  2. submersible pump for water and georthermal heat/cool system does not work.
    By Imnanagma in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-22-2010, 10:36 AM
  3. Submersible pump vibration noise
    By M3 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-16-2009, 01:27 PM
  4. vibration in sprinkler system
    By jesi in forum Irrigation / Sprinkler Forum
    Last Post: 07-28-2008, 01:36 PM
  5. hand shower causes knocking/vibration in pipes
    By stamp in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-20-2008, 04:40 PM
