Hi there. I have a Toto Ultramax with a GMax Type A fill valve that seems to need repair or replacement (toilet keeps running, valve continues sending water into the tank even after the tank is full, causing water to constantly run down the overflow tube).
Is there a Korky product that I can use for this? All of the references I have seen to Korky fill valves appear to be the "type B" style. If my toilet originally had a "Type A" fill valve, can I replace it with a type B? The photo attached is the kind that is in my toilet right now.
I'm trying to find a way to use something I can buy at Home Depot, rather than special-ordering one from the manufacturer.
Thanks -
JD
Thanks -
JD
