Results 1 to 8 of 8
Thread: Help solve an "argument" about a DPST thermostat for my ceiling heat?
    DIY Junior Member Blind Frog's Avatar
    Aug 2012
    Western Ohio
    Question Help solve an "argument" about a DPST thermostat for my ceiling heat?
    My electrician buddy was admiring my new Honeywell LineVolt Pro 8000 (TL8230A1003) as we prepared to install it. This is a DPST model (two red/two black). I told him I would like to find similar models for my SPST units (One red & one black wire) for my smaller rooms. He said that since I got the thermostat at a great price, I should just do all the rooms with the same DPST model. He said I should simply pigtail both reds and both blacks (Line & Load) and then tie into the existing wiring. I told him this either could NOT be done or it would shorten the life span of the stat. He says I am an idiot. We have a pitcher & pizza riding on it.
    [QUOTE=Blind Frog;353837. He says I am an idiot. .[/QUOTE]
    Right on!!!!!!!!!!
    Aug 2012
    Western Ohio
    jimbo - HEY!!! At first I was worried you were saying he was right and I was wrong...then I noticed you are a PLUMBER and not an electrician, so I know you are all wet and your answer can be flushed down the drain!
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    Check out this image and you surmise who is incorrect
    Aug 2012
    Western Ohio
    CRAP!
    I do not agree with the drawing of the DPST switch above! A double pole (two paths), single throw (essentially an on/off switch) is commonly used to break BOTH leads of a 240vac device...it is essentially a two pole on/off switch. It is safer since it actually removes power entirely from the device, whereas a SPST switch on a thing like a 240vac heater does stop it from operating, but there's still voltage applied to the device. If it developed an internal short, or you touched something in it and were connected to ground, you could fry yourself. SPDT and DPST are reversed in the drawing.
    Jun 2010
    USA
    Yep. These look better. Copied that image from google...
    http://www.kpsec.freeuk.com/components/switch.htm
    Quote Originally Posted by Blind Frog View Post
    I was a Master Chief Electronic Technician in the Navy, couple that with on a submarine everyone learns about everything, I feel eminently qualified to comment on switches!
  1. Termosyphon system and closed loop copper heat exchanger "dillema"!
    By leaualorin in forum Solar and Geothermal Water Heating Forum
    Last Post: 11-27-2011, 02:02 PM
  2. ceiling fan lights "pop" and went dead
    By Ed from chicago in forum Electrical Forum discussion & Blog
    Last Post: 08-07-2010, 05:20 PM
  3. "Machine Gun" or "Thud" and a Weeping Toilet...oh my!
    By maxxis in forum Plumbing Forum Discussion & Blog
    Last Post: 03-22-2009, 07:38 PM
  4. water heater "heat loops"
    By edwardh4 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-18-2008, 04:08 AM
  5. Difference between "thinset" and "dryset" mortar...?
    By Fistor in forum Remodel Forum & Blog
    Last Post: 07-31-2008, 02:44 PM
