Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: Construction questions on steam shower and bath reno
    DIY Junior Member jla's Avatar
    Aug 2012
    Michigan
    Default Construction questions on steam shower and bath reno
    After listening to both John and Jim on this forum, I am going to be posting questions I may run into while construction is begun on my bathroom reno which includes a Thermasol steam shower as well as an air tub, heated floor, and 6' vanity with double sinks.
    1. Is it necessary to do a tile "test board"? I am told this is apparently not a common practice.
    2. The slope on the steam shower ceiling will be about 6". Is that ok?
    3. There will be a 24 hr. flood test. Is that adequate as opposed to 72 hr which was mentioned by John?
    Thank you for all of your help.
    1. It can help you visualize the tile spacing, grout color, and placement to help you decide before you commit to the whole job, but no, it isn't essential.
    2. That may be more than needed...I'd have to look it up to be sure, but I would think a minimum of 1/4" per foot.
    3. If it doesn't leak in 24-hours, it's unlikely to leak in 72, but if you have the time, it won't hurt. The longer it sits, the more you have to account for evaporation, otherwise, you'll get a false indication when it does drop some. But, it would disclose wicking or leaks into the wall or floor, if you have access to see it (which may not be the case for all sides).
    Jul 2009
    North Vancouver, BC
    Default Steam Shower Construction - Check List (Design Stage)
    Post(s) deleted by John Whipple
    Jul 2009
    North Vancouver, BC
    Default Steam Shower Construction - Check List (Pre-Slope Stage)
    Aug 2012
    Michigan
    John,
    I would like to run everything by you as far as proper steps taken, materials used, etc. concerning my steam shower. My reno is at the point where studs are in, and the electrical and plumbing is underway. At this point, I want to make sure I am asking all of the correct questions. Besides asking what the process of waterproofing and vapor proofing will be, is there anything else I should ask as far as any products/materials used for membranes, sealing,etc. before any further work is done and walls go up?
    Jul 2009
    North Vancouver, BC
    Default Steam Shower Construction - Check List (Framing Stage)
    Aug 2012
    Michigan
    Curb question: For the steam shower is a synthetic shower curb preferable to a natural stone curb or doesn't it really make a significant difference? Thanks.
    Vanity question: Because there is a steam shower, is one wood preferable over another as far as vanity material? I am considering cherry.
    Jul 2009
    North Vancouver, BC
    Aug 2012
    Michigan
    John,
    That would be great if you had a picture of the metal accent for the vanity or had a name for it and/or description.
    The curb sold at our tile store is a 6 x 48 synthetic and has a threshold for our entrance to match which is 4-1/2 x 36.
    Also, what is best to use joining all around the ceiling of the shower to the shower tile walls? Is bullnose the best or a metal strip like a schluter?
    Thanks again.
    Jul 2009
    North Vancouver, BC
    Aug 2012
    Michigan
    John,
    I would like to get information on a frameless,clear glass shower door choice and installation for the steam shower. Is it best to have a transom at the top or no--pros and cons? It would seem that a transom would be preferable especially when the steam is not in use.There is one vent fan in the bathroom (outside the shower).The standard glass thickness is 3/8" and I will assume that is fine. Fyi-shower height is 94", shower dimensions are
    57" x 40". The shower placement is on a bit of an angle between the entrance door and the tub (the tub deck forms the seat of the shower). This would make the glass door hinged on the left side, opening towards the bathroom entrance door. As far as making sure hinges are sealed properly, I have read your comment about not using silicone to fill the drill holes but I thought silicone was used properly to fill in plumbing fixtures (shower controls,head, etc.)at some point. Also, any opinion about the "protection" baked into the glass for easy cleaning,reduction of bacterial growth, etc.? Would love info of the metal accent detail of the vanity. Your help has been invaluable and is much appreciated.
    (by the way, I totally misunderstood my contractor on my previous question about the ceiling/wall shluter so ignore, sorry).
    Jul 2009
    North Vancouver, BC
    Default Steam Shower Questions and Answers
    Have you ever used Rain-X or one of the competing products on your car's windshield? Have you ever had a pair of glasses made with the Crizal AR coating? The coatings fill in the microscopic valleys of the glass and make it 'smoother'. Stuff doesn't stick as easily, and water beads up and flows off easier similar to a recently waxed car. Whether is it a huge difference or not, it will make some difference. It's up to you whether you wish to spend the money for it. See if your glass supplier can show you a sample both with and without - run some water over it, wipe it off, see what you think.
    Jul 2009
    North Vancouver, BC
    Jul 2009
    North Vancouver, BC
    Default Steam Showers and Air Tubs - Luxury at it's best!
  1. Steam shower Construction
    By dradam in forum Shower & bathtub Forum & Blog
    Last Post: 10-23-2013, 01:27 PM
  2. Advice for new construction bath/shower thermostatic valves & handles
    By monty in forum Shower & bathtub Forum & Blog
    Last Post: 06-27-2011, 08:45 AM
  3. Clueless Newbie Full Bath Reno... Oh Noooo!
    By duct tape pro in forum Shower & bathtub Forum & Blog
    Last Post: 04-18-2007, 07:53 AM
  4. Bathroom reno questions
    By crossthreaded in forum Shower & bathtub Forum & Blog
    Last Post: 03-10-2007, 02:46 PM
  5. no hot water in bath/shower - new construction
    By clarkin in forum Shower & bathtub Forum & Blog
    Last Post: 06-27-2005, 08:12 AM
