I am renovating the condo and trying to replace the Americian Standard wall hung toilet has been there since the condo was built in the 50s.
The problem is that American Standard no longer make this gravity flush wall hang toilet. Crane used to make the Rexmont wall hung toilet but it has been discontinued. The Americian Standard replacement model is the Glenwall pressure assisted siphon jet action toilet. The condo association does not allow pressure assisted due to the noise it makes.
So I got creative and looked into on using commercial toilet (Toto wall hung, CT708EV) with a flushometer valve (Toto, TET3GN31#SS). We have water line that is 1" and the water pressure is well above 30 psi. However, my concerns are that 1) does siphon jet make loud noise also? more or less than pressure assist? 2) anything thing I should be concerned or aware of installing a commercial toilet at home? 3) any alternative solutions?
Thank you!
Thank you!
