Results 1 to 12 of 12
Thread: Gap between ceiling fan housing and ceiling
Hybrid View
    DIY Junior Member hfx's Avatar
    Aug 2012
    Johnson City, TN
    Default Gap between ceiling fan housing and ceiling
    Hunter ceiling fan:
    Hi I was wondering if anyone had experience with ceiling fans and could tell me what the deal is with the gap I ended up with between the housing and the ceiling. It almost looks like the bracket was made to hang down some, the instructions didn't say anything about bending it to fit flush with the ceiling, just curious if anyone had the same issues.
    Name:  IMAG0941 (Medium).jpg
Size:  48.8 KBName:  IMAG0943 (Medium).jpg
Size:  45.7 KBName:  IMAG0944 (Medium).jpg
    Mar 2011
    Long Island, NY
    Is the ceiling box (hopefully fan mounting designed and rated) flush or slightly receeded with the sheet rock? Are you able to spread those wires apart somewhat as a seperate issue?
    Aug 2012
    Johnson City, TN
    Thanks. Yea the box is recessed 3/16" or so (yep its made for and mounted for ceiling fan, thanks). You saying I need to give the wires some breathing room from each other? I could probly do that, can I ask why, just so I know.
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    it looks like you're missing a trim ring that covers the screws. Mine has a cover that slides over those and covers that same gap.
    Jun 2007
    North Carolina
    Quote Originally Posted by Chad Schloss View Post
    Yours hangs on a stem and his fits flush to the ceiling but I don’t see anything wrong.
    I would much rather have the small gap as to have it damage the texture of the ceiling trying to install it.
    DIY Junior Member oldanbo's Avatar
    May 2006
    Sequim,WA
    HEY, that's my fan! HD or Lowes, I forget.
    Mar 2011
    Long Island, NY
    Quote Originally Posted by hfx View Post
    If the gap bothers you, a medallion may work for you to hide it. HD and Lowes sell a variety of them. You could also call the manufacturer's customer service to see if they can suggest any possible adjustment. I agree with JW, though. More often than not, it is difficlult to force the canopy up against the ceiling while trying to get those screws threaded into the holes.
    I mentioned the wiring because it does not look so neat. I have installed enough ceiling fans to know that it is not always so easy to make it neat, but I always try.
    Sep 2009
    Seattle. WA
    Looks like good ventilation design to me.
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    I agree! I'd leave it alone. No one, but you, will ever look at this and think, "What a horribly wide gap!" And you will soon think of other things and will stop noticing it.
    Mar 2011
    Houston, TX
    Quote Originally Posted by kreemoweet View Post
    That is what I was thinking, It will sure run cooler.
    Plus the spiders have a escape route.
  1. What should I do with this ceiling.
    By Cappy in forum Remodel Forum & Blog
    Last Post: 05-02-2009, 06:17 AM
  2. Tub leaking into ceiling
    By lclose in forum Shower & bathtub Forum & Blog
    Last Post: 01-22-2009, 04:31 AM
  3. Ceiling fan
    By Tom Lehtonen in forum Electrical Forum discussion & Blog
    Last Post: 03-22-2008, 06:25 PM
  4. removing old bathroom ceiling fan housing
    By Karen in Seattle in forum Remodel Forum & Blog
    Last Post: 09-18-2007, 08:38 PM
  5. Installing Ceiling Fan On Vaulted Wood Ceiling
    By Verdeboy in forum Electrical Forum discussion & Blog
    Last Post: 08-17-2007, 08:10 AM
