Results 1 to 5 of 5
Thread: Need Some Guidence No Sprinkler Function
    DIY Junior Member Vinnykidd's Avatar
    Aug 2012
    Florida
    Default Need Some Guidence No Sprinkler Function
    Had a sprinkler system professionally installed about 6 years ago. Had been working flawlessly until a few weeks ago. It runs once a week for four zones. Started to trouble shoot it today and can offer this info. My Rainbird control in the garage works like it always has and when I manually turned on the sprinklers today it clicks like it always has on and off. What I did notice is that my pump will turn on for a few seconds and then shut down, but it sounds like it always has It does this for all four zones. Also I opened up the faucet on my pump and water will come out of it while the pump does run for those few seconds before it shuts down. All four zones though do not ever come on. I took a peak at my cellinoids but need assistance on what checks to make. I doubt all four zones failed but we did have a tropical storm come through here a about a month ago with lots of rain and lightning. I have access to a meter if there's a way to test voltages on all the items. Thanks
    Plumber jimbo's Avatar
    Lightning will fry a controller. At the outlet terminal board of the controller, you should have 24 volts ac ( measured to COMMON terminal ) at the pump start terminal, and also at the # zone which is supposed to run. If you do, the thing that is common to all zones IS the COMMON wire. Something may have happened to that connection out in the yard.
    Aug 2012
    Florida
    Thanks for the help, I'll check all that out this weekend. Luckily we have had rain every few days so, the down time on the lawn has not been too harmful. I'll reply back if I need any more assistance. Thanks
    Yakima WA
    I'm with Jimbo on this. Something has happened to the common wire. Could be at the controller or it could be at the wye going to the first valve since none of the valves come on. If the wire was loose or broken after the first valve, the first valve would work, but the rest would not.
    Aug 2012
    Florida
    I think I've pretty much narrowed down my problem to a bad pump start relay. I called Rain Bird customer support and they had me run some checks and I was able to hear the coil in this relay arc. It's a HX20-S32 rated 32A with a coil volt 24V 50/60 Hz I ran to Home Depot and they had the whole kit with a housing, different brand, but the guy there said I'd most likely have to splice some wires to match it up to the new one. I'd like to just find this one and bolt it into my existing housing and be done with it. Any suggestions. Also, it seems that A/C units, might use this relay as well? Thanks
  1. search function broken
    By JuanSigned in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-22-2011, 10:20 AM
  2. Solenoid function on a irrigation valve?
    By pmaru77 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2009, 07:27 PM
  3. Separate or 3-Function Shower Controls
    By kendog2 in forum Shower & bathtub Forum & Blog
    Last Post: 03-14-2009, 06:20 PM
  4. Plumbers Putty Function under Faucet
    By molo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-30-2007, 04:54 AM
  5. Oil Boiler Anti Freeze Function?
    By freezing in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-21-2007, 03:14 AM
