Results 1 to 5 of 5
Thread: valve between hose bib supply - softened and untreated
Hybrid View
    DIY Senior Member lifespeed's Avatar
    Apr 2007
    California
    Default valve between hose bib supply - softened and untreated
    The hose bib take-off from the city raw water is only 6 feet from the filter/softener outlet. Shouldn't I join them with a full port three way valve to be able to select softened water at my hose bibs for washing the car, windows, skylights, etc?
    Would I be hopelessly optimisitic to think occasionally filling the hose bib copper pipes with softened water would have any effect on scale? They're new, not scaled yet.
    Washing anything in softened water is preferable to washing it in hard water.
    It will take decades for your hard water to put down enough scale to cause any problem.
    Nov 2010
    Maine
    Yea, go ahead and run the bypass.
    Feb 2011
    NW Ontario, Canada
    Why not simply install a couple of new hosebibs with hot and cold soft water? I have hosebibs with four different water types; raw unfiltered well water, iron filtered/unsoftened, iron filtered/softened hot and iron filtered/softened cold.
    Apr 2007
    California
    Switching the hose bibs with a valve at the raw water junction is 6 feet of plumbing. You're suggestion is about 100 feet, although admittedly very convenient.
  1. Source for metric thread (15mm x 1.0mm) supply hose
    By JMThomas in forum Plumbing Forum Discussion & Blog
    Last Post: 07-14-2011, 02:07 PM
  2. Toilet Supply Hose leaks after showering
    By stotzies in forum Plumbing Forum Discussion & Blog
    Last Post: 06-13-2008, 07:02 AM
  3. Delta Brizo supply hose leak. Help Please!
    By Jaret in forum Plumbing Forum Discussion & Blog
    Last Post: 02-25-2008, 07:41 AM
  4. braided dishwasher water supply hose 10ft
    By dave007 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-07-2006, 03:13 PM
  5. Hose to valve. Solid pipe or hose, which is better?
    By bnbhoha in forum Toilet Forum discussions
    Last Post: 12-19-2005, 07:36 AM
