Results 1 to 2 of 2
Thread: Tub drain gasket needed?
    DIY Junior Member Why did I try this?'s Avatar
    Aug 2012
    Wisconsin
    Default Tub drain gasket needed?
    Hi,
    I will be reusing the piping for the tub drain. The old tub squished a gasket between the pipe and the bottom of the tub. Is this still needed or can Teflon tape and plumbers putty be used?
    Also with the overflow there was a Moen gasket that slipped over the flat part of the pipe(the part the drain face plate screws into) and then the sleeve part of the gasket got pushed into the tub. Is there an alternate way to seal an overflow pipe or should I try to find a replacement gasket?
    Thank you
    Mar 2011
    Long Island, NY
    Quote Originally Posted by Why did I try this? View Post
    Hi,
    Thank you
    Those gaskets are sold even at Ace harware stores packaged and labeled for that purpose.
  1. Size of neoprene gasket on CI drain
    By TJanak in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-05-2011, 09:12 AM
  2. Pros & Cons of Wax Free Gasket versus Wax Gasket on Toilet Installation
    By herbolaryo in forum Toilet Forum discussions
    Last Post: 09-02-2011, 01:48 PM
  3. Leak from overflow gasket on tub drain
    By yaozer in forum Shower & bathtub Forum & Blog
    Last Post: 11-21-2009, 06:15 AM
  4. Gasket or putty under bathtub drain lip?
    By npurdy506 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-06-2009, 05:31 AM
  5. Leak from replacement drain gasket
    By Paddy Coughlin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-30-2004, 07:31 PM
