Results 1 to 7 of 7
Thread: 2 1/2" ABS as underground conduit, Plumbers, HELP!
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Default 2 1/2" ABS as underground conduit, Plumbers, HELP!
    Guys,
    I am looking at needing to cut and add a sweep to some underground conduit, as the arrangement of the service has changed.
    This was installed 40-50 years ago. The crud is down 5' in a hole and is tough to get at.
    What sucks: it looks like 2 1/2" abs. It certainly is All Black Stuff. But no such size exists.
    It really is down pretty far. Any deeper and I could drop a casket in there. So I am having difficulty working out exactly what it is.
    So I wonder, is it in any practical way possible to join ABS to grey pvc? That I can get in 2 1/2", including a sweep.
    I wonder if I need to just use a rubber coupling?
    Or have I got it all wrong, and the stuff is actually 2"? I would not put it past the local utility...
    Mar 2011
    Houston, TX
    Quote Originally Posted by Homeownerinburb View Post
    Guys,
    Not sure but that sounds like it could be a Gas line.
    I would check it before I started cutting.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Jan 2012
    Los Angeles, CA USA
    No, no. The gas comes in quite elsewhere.
    The general had a utility spotter mark things.
    Got it worked thru today. Believe it or not: two #2 and one #4 aluminum, in 1 1/2" abs.
    And we are replacing the 100 panel with a 200 amp panel. It has been approved. I don't get it.
    Jun 2007
    North Carolina
    the answer lies in the utility rules not the NEC.
    THere should be a lot of difference in the "looks" between 2 1/2" and 1 1/2" conduit.
    Mar 2011
    Long Island, NY
    Hi Don. Eating too many bean burritos makes everything sound like a gas problem
    Jan 2012
    Los Angeles, CA USA
    Yeah, it was 5' down in a pit. Hard as hell to work on in any way.
  1. Underground conduit and pull-box questions
    By charp in forum Electrical Forum discussion & Blog
    Last Post: 10-06-2011, 03:02 AM
  2. Underground conduit
    By JAR8832 in forum Electrical Forum discussion & Blog
    Last Post: 03-27-2010, 07:45 PM
  3. Can "any" schedule 80 PVC be used as electrical conduit...
    By itr674 in forum Electrical Forum discussion & Blog
    Last Post: 01-28-2010, 03:10 AM
  4. Can THW wire be used underground in conduit?
    By pyro9862 in forum Electrical Forum discussion & Blog
    Last Post: 12-16-2009, 06:49 PM
  5. MN-B, 12-3/GRD inside 2" PVC conduit
    By Ford2001 in forum Electrical Forum discussion & Blog
    Last Post: 09-21-2009, 07:28 PM
