Thread: Question about 3 compartment sink installation and mop sink
    DIY Junior Member lcafe's Avatar
    Aug 2012
    Long Beach, CA
    Default Question about 3 compartment sink installation and mop sink
    Quick question. I am in California. I am installing a 3 compartment sink in my business which is going to operated under a 'food facility' license. Does the sink need to have it's own valves. I have a main valve for the cold water , and another valve for the hot water. These valves control water flow to both the mop sink and 3 compartment sink. Do I need separate valves for both the mop sink and the 3 compartment sink? I know it can be useful to have but not sure if anybody knows if it's absolutely necessary? I can't seem to find anything related to this under CA health & safety code which is odd..
    A contractor came in and rebuilt the bathroom up to code. He also installed two valves and water lines coming out of the wall in the first photo near the bottom right. One valve controls the cold water out, the other is to send hot water in from the water heater which goes back to the bathroom sink.
    My initial plan was to install two additional separate valves that control hot and cold water flow to the 3 compartment sink, and another two separate valves that control hot and cold water to the mop sink. That way I could control water flow to each independently however it seems rather unnecessary because if i needed to shut off water flow in the back area quickly it would make more sense to have 2 master valves verses 4.. unless i'm wrong?
    The photos below aren't complete but give a quick idea of what i have ..
    The mop sink has it's own drain into the wall which goes down into grey water.
    The 3 compartment sink has it's own drain which goes into the ground with an air gap between the floor drain twice the diameter of the drain pipe
Size:  31.3 KBName:  081612014643.jpg
    IT would be nice if the photos actually showed something, but they are both too dark. With those supply lines, they should be attached to "angle stops" at the water line, and, if so, I do not see a reason for your question.
    Aug 2012
    Long Beach, CA
    That answers my question , thanks!
    sorry about the dark photos , low light in the room but high gama on my monitor.
  1. 3 compartment sink draining problem with grease trap
    By pizzaworker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2010, 07:23 PM
  2. Stainless Sink installation question
    By Reg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-04-2009, 10:20 AM
  3. Pedestal sink installation question
    By khayes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-16-2007, 05:52 AM
  4. Pedestal Sink Installation Question
    By chetwynd in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-10-2006, 07:42 PM
  5. Vanity/sink installation question
    By jumpyg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2005, 07:21 AM
