Results 1 to 8 of 8
Thread: Best Mortar for Shower Stall
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Best Mortar for Shower Stall
    Hello,
    What is the best choice for mortar below a shower stall? I would think a mortar that does not crack or shrink.
    Thanks,
    Bill
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Jul 2009
    North Vancouver, BC
    Great question. Maybe try asking on the John Bridge Tile Forum.
    Or try out this online school. http://www.uofcts.org/
    JW
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by molo View Post
    Hello,
    Thanks,
    Bill
    Bill I'll assume you mean under the shower pan (fiberglass type).....
    When installing mortar under tubs and showers pans we just use Mason Mix (type used for setting bricks).
    I do not want the tile to bond to the underside so we use poly as a bond breaker.
    Each install depends on what the bottom looks like so we tackle each on a case by case basis.
    Each manufacture will have a preferred system in place. If they have none I would look for a supplier who allows this step.
    Some of the pans have large segmented sections that are hard for the mortar and air to escape when setting them in place. The key area is around the drain. Often the subfloor is not supported from below.
    Any pictures you can upload?
    JW
    Sep 2006
    cold new york
    "Sand Mix" is a product that a Sakrete rep. recommended. He said it was the best choice for under shower stalls.
    Gore Vidal.
    Sand mix is what you make a shower pan out of. If it is rich enough, it will smush, but out of the bag, it may be so coarse, it won't smush easily...think wet beach sand verses something that will flow a bit. The more water, the more likely it will shrink and crack. More cement in the mix will make it move a little easier. Not sure what their sand:cement ratio is in the prepackaged stuff...if it's in the 3:1 range, it will still pack, but have enough cement to flow a bit. A bunch of piles rather than trying to make it flat first works better.
    Sep 2006
    cold new york
    It was a 5,000 psi mix that Sakrete recommended. It was quite thick when I put it down, but I wouldn't have wanted it so thin that it didn't stay in place.
    I put down an inch layer and it was difficult to get the fiberglass base all the way down to the floor. In fact I ended up leveling the base and allowing the base to sit in the mortar about a 1/2 inch off of the subfloor. It is fully supported by all of the mortar that was put down.
    The sand mix:
    http://www.sakrete.com/products/deta...alias/Sand-Mix
    Gore Vidal.
    Jul 2009
    North Vancouver, BC
    Did you bond straight to the subfloor and base? Or did you use a bond breaker like some poly?
    Have you tapped around the base looking for hollow sounds?
    How well supported is the area around the drain? This is the weak point in the shower system...
    JW
    DIY Junior Member Scott Vroom's Avatar
    Feb 2010
    Mountain View, CA
  1. Bifold Shower Door For Stall Sized Shower 40.25" Wide
    By turbocruiser in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2011, 04:57 AM
  2. Convert Slab Shower Stall to Level Floor for Steam Shower Unit
    By Saitek in forum Shower & bathtub Forum & Blog
    Last Post: 02-13-2010, 02:09 PM
  3. Mortar under Shower
    By molo in forum Shower & bathtub Forum & Blog
    Last Post: 01-14-2007, 11:01 PM
  4. Shower Pan set in mortar
    By BSwanson in forum Shower & bathtub Forum & Blog
    Last Post: 05-23-2006, 07:40 AM
  5. Turning walkin shower stall into bathtub/shower combo
    By Brian_Houston in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2005, 05:13 PM
