Thread: Drainage issue
    DIY Junior Member Austin1983's Avatar
    Aug 2012
    Texas
    Default Drainage issue
    Hello everyone, I'm new here, and I'm in the process of purchasing a new (to me) home. The inspection revealed that rain water was flowing down the neighbors yard towards the house. The inspection showed very minor upheaval in the center of the foundation possibly due to the poor drainage. He suggested adding a french drain to prevent any foundation issues, but of course $2500 for a french drain is a little tough while purchasing a new home. What about digging a channel that would allow the water to flow naturally towards the street? I've included a photo from the house we are looking to purchase, and a nearby neighbor who dug a channel in his yard. Any advice or suggestions would be greatly appreciated. Thanks in advance.
    The original builders of those houses did one craptastic job of siting the houses for proper drainage. Reminds me of my own place Anyway, digging a drainage swale will work fine as long as you have a slope toward the street. Another thing you should look at are those downspouts. Extend them away from the foundation and in a direction where the natural slope of the property will continue to carry the water away from the foundation.
    Feb 2011
    NW Ontario, Canada
    +1 on your own downspouts being the larger culprit. A swale need not be as ugly as the one you posted and can be made much more gentle. The effectiveness of the swale though will depend on the pitch and what material is under it. I suspect that the material that close to the house would still let the water soak down to the foundation.
    I suggest a french drain under a gentle swale for a belt and suspenders approach. Line the bottom of the swale with clay material if as I suspect there is coarse builder's sand.
  1. Drainage issue
    By steve-in-ga in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-17-2009, 05:56 AM
  2. Drainage Issue
    By mattypichu in forum Drain Cleaning
    Last Post: 01-21-2009, 04:24 AM
  3. Drainage Issue
    By mattypichu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  4. Odd drainage issue needing creative help
    By grendlesgirl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-04-2007, 11:27 AM
  5. Tub drainage issue
    By Serg in forum Shower & bathtub Forum & Blog
    Last Post: 07-05-2006, 04:38 PM
