What you describe sounds like an intermitant short, probably in the common wire. I would check the wire connections and probably redo them even if they look good. I have had many cases where a connection looks good but still causes a problem until it's redone.
I have a Hunter Controller (residential) Recently the system comes on for a second and then shuts off. I can open all the valves manually and they work fine, but the controller only allows the system on for a split second. sometimes it will work flawlessly for a week. I might mention I cannot turn on any single station from the controller when it it acting up.t starts for a second and then shuts off. Any ideas would be welcome.
