Results 1 to 4 of 4
Thread: plumbing brands compatible with newport brass plumbing threads
    DIY Junior Member kcamp's Avatar
    Aug 2012
    california
    Default plumbing brands compatible with newport brass plumbing threads
    i am remodeling a shower. the faucets are 18 year old newport. i don't want to do demo on tile. i just want to easily replace faucets and not buy newport brass cause it is so expensive. any ideas?
    Sep 2009
    Seattle. WA
    You're dreaming. There is little to no interchangeability among different makes of plumbing fixtures. If you can open the wall on the non-tile side, it "might" be
    possible to install different valves/faucets without disturbing the tile.
    SOMETIMES, an upscale brand, such as Newport, uses the parts from a mainline company, such as Central or Pfister, as its base. In those cases, you can use parts from the original manufacturer to redo it. But, you have to do due diligence and determine whether the base is proprietary or not.
    Many (most?) companies make their internal parts such that they specifically aren't interchangeable with other companies stuff thus forcing you to buy directly from them. The only thing (usually) guaranteed to be universal is the end connection to the supply so you can hook it up and that may even be a proprietary adapter.
  1. UPC Plumbing Code, Helpful Hints by Bert Polk Plumbing inspector
    By Terry in forum UPC Plumbing Code Questions
    Last Post: 02-18-2013, 02:27 PM
  2. Brass Plumbing - Rip out as much as one Can
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-01-2012, 06:00 AM
  3. Bad brass threads?
    By M3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2010, 01:47 PM
  4. Water heater brass threads question
    By luvmylars in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-02-2008, 07:06 PM
  5. Newport Brass Faucet Replacement Cartridge
    By catherine Landa in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2007, 11:17 AM
