Results 1 to 5 of 5
Thread: iron removal
    DIY Junior Member curt21's Avatar
    Jul 2012
    Newfoundland
    Default iron removal
    Lately I've noticed rust colored staining on toilet bowk and a brownish red residue left on white clothing after wash cycle. My well water also has an odor that is earthy/metallic. I believe the issue is a high iron content. What is the easiest way to remove it: Water softener, sand filter, some type of cartridge filter or something else? A water softener is my last resort but is it the best choice? Thank you
    Feb 2011
    NW Ontario, Canada
    While a softener can remove some iron, I don't advocate using one for iron removal. There are backwashing iron filters that do a much better job removing iron. Most work on the principle of aerating the water to oxidize the iron so that it precipitates out to be trapped by the filter media.
    Jul 2012
    Newfoundland
    I have a rain fresh whole home filter in my main line - will a ceramic .3 micron filter with a carbon core (as sold by canadian tire, etc.) reduce the iron for a temporary fix?
    Jul 2012
    Newfoundland
    Here is another thought/question: I've read online that chlorination can be very beneficial for iron removal, sulfur odor removal, bacteria treatment etc. Since I am running of a shallow well would it be a good idea to regularly treat the well with a certian amount of chlorine solution (the well is a metal casing 24"diameter). I dont use the water for drinking, but would the chlorine be very corrosive to the metal/galvanized casing?
    Feb 2011
    NW Ontario, Canada
    They do make pellet feeders that drop directly into the well. From what I hear, they can corrode the casing.
    If there is a bacteria problem that is causing the smell, the chlorine should help. The chlorine will also oxidize the iron out so that it precipitates to be trapped by a filter.
    My well water looks clear when first drawn but let to sit, turns brown and develops what looks like an oily sheen. It has a noticeable smell. I aerate the water with a micronizer and then filter it with a BIRM filter. After that, it no longer has any smell.
  1. Iron removal
    By F6Hawk in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-12-2012, 02:29 PM
  2. Iron Removal Question
    By jlbartley in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-18-2011, 12:13 PM
  3. 3" Cast Iron Cleanout (in Wye? Removal
    By CapstanRec in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-21-2010, 11:48 AM
  4. Iron Removal for single tub.
    By Gast in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-18-2010, 10:01 AM
  5. Softeners, resin, and iron removal
    By Ddanrr in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-04-2009, 08:42 PM
