Results 1 to 5 of 5
Thread: Help me identify this shower cartridge!!
    DIY Junior Member krystal138's Avatar
    Aug 2012
    Alberta
    Default Help me identify this shower cartridge!!
    My house was built in 2009, about 6 months ago the water in the shower went from hot to warm. I called a plumber and he said i need to order a new cartridge. The problem is there are no markings on the shower or any of the parts and I have not been able to match it up in any stores or online. Please help me identify this shower/cartridge!
    DIY Junior Member allforone's Avatar
    Nov 2012
    Toronto, ON
    Quote Originally Posted by krystal138 View Post
    I have the same problem. I turn the mixer to the hottest position, but the water is still a little warm. The cartridge is almost the same. I can only identify "Selection" on the cover, nothing else. But nobody ever heard of that brand.
    You get A+ for all the right photos! I can't ID it personally, but someone will. Stay tuned!!!
    In the Trades Towers Plumbing's Avatar
    Nov 2012
    Salt Lake City, UT
    Default Moen Exactemp
    Those cartridges look like an older style of the Moen ExactTemp® shower valves. The large white valve with the screens is the thermostatic mixing valve and the second valve is most likely a ceramic volume control cartridge.
    mixing valve cartridge $120
    http://www.moen.com/shared/docs/expl...ws/s3371pt.pdf
    volume control cartridge $22
    http://www.moen.com/shared/docs/expl...ws/s3600pt.pdf
    Note the second page for valve built before 2009. Older model cartridges can still be ordered but not directly through Moen. It goes through Moen but my distributor is the only way I can order it. Might want to check with a local plumbing supply warehouse.
    Good Luck.
    DIY Junior Member shaolin_dragon's Avatar
    Oct 2006
    VA
    Quote Originally Posted by Towers Plumbing View Post
    Good Luck.
    Negatory good sir. That is not a Moen. The trim is all wrong and the lower cartridge on the 2 handle 1/2" ExactTemp was a 1248 roman tub cartridge. The newer 3/4" exactTemp do not have a dual handle configuration. Only single.
    Good luck on the hunt.
  1. Help needed to identify mixer cartridge
    By PZM in forum Shower & bathtub Forum & Blog
    Last Post: 11-14-2012, 07:17 AM
  2. Can someone help identify the cartridge brand/model? Moen Posi-Temp
    By tr1006 in forum Shower & bathtub Forum & Blog
    Last Post: 11-13-2012, 04:25 PM
  3. help identify cartridge
    By waynevpearson in forum Plumbing Forum Discussion & Blog
    Last Post: 08-16-2010, 08:42 AM
  4. Can anyone identify this shower cartridge?
    By deepdrop in forum Shower & bathtub Forum & Blog
    Last Post: 07-17-2010, 02:01 PM
  5. Can not identify shower faucet
    By Mike45 in forum Shower & bathtub Forum & Blog
    Last Post: 02-12-2007, 03:42 PM
