Results 1 to 2 of 2
Thread: Quarter-turn valve
    DIY Senior Member SamC's Avatar
    Apr 2007
    Georgia
    Default Quarter-turn valve
    I have read posts recommending replacing the usual multi-turn inlet valves on toilets with quarter-turn valves, since the valve is always fully-open or fully-closed. Is there a sealing advantage to the ball valve used in the quarter-turn models? Would it also be worthwhile to replace the same valves on all the sinks?
    When remodeling (or new), my preference is to use 1/4-turn, ball valves. On a conventional stop, the rubber washer can become hard and brittle so when you turn it off after not being touched for maybe decades, it can break apart, and never seal when you need it. A ball valve usually works more reliably. I probably wouldn't just decide to replace what was there unless I was swapping out say the faucet or changing the toilet, or, obviously, if I needed to do some repair, and the existing valve didn't shut off. It's much nicer to not have to turn the water to the house off when doing a repair, course, that main shutoff may no longer work, either!
  1. Quarter-turn, frost-free, anti-syphon faucet shuts itself off
    By RavenG in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-23-2012, 03:32 PM
  2. Sillcock Types, Conventional vs. Quarter Turn
    By sagittaire in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-22-2011, 06:28 PM
  3. quarter turn angle valve1/2 sweat
    By coopns in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-11-2010, 02:20 PM
  4. Quarter turn plug
    By SamC in forum Shower & bathtub Forum & Blog
    Last Post: 02-14-2008, 09:55 PM
  5. Quarter turn Sillcock Leak
    By novice 1832 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2007, 01:43 PM
