Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: Please help me document my well and water system
  1. #31
    DIY Junior Member SimonT's Avatar
    Aug 2012
    Midwest
    With the bolt replacing the screw I would guess its full open I now have a GPM of 3.5
    I have done a lot of calling around and I think I found a blue plastic Hydrocharger/ventur for about $60
    SWT also has a plastic unit as well but still trying to get pricing http://www.swtwater.com/catalog/1215_air_injectors.htm
    But as you first posted in its basic design a ventur will drop my GPM so maybe its better to look at a airpump method but then should I also look at a holding tank as well.
  2. #32
    Feb 2011
    NW Ontario, Canada
    Take advantage of the extra GPM you have now, and do a manual backwash. If it doesn't run relatively clear by the end of the first one, do two or more.
  3. #33
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by SimonT View Post
    ...should I also look at a holding tank as well.
    The air needs contact time for best results. Bladder tanks are not usually used as precipitation tanks. Over time the iron may build up between the sides of the tank and the bladder.
  4. #34
    Aug 2012
    Midwest
    Did a manual wash in to a bucket to look at water and it was pretty clear after 3rd 5Gal I put hose in the drain and then rocked and banged the side of treatment unit. But water was stil clear.
    Water noise as it go's in tank is not so loud now as I guess water is not being forced through such a small opening.
    Yer I read that for iron filters that use air the longer the water is held the better thats why a pressure tank is not so great.
  1. Water softener WHES40 & Central Water Filtration System - Questions
    By reggiev6 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-16-2011, 10:57 AM
  2. Culligan Water Softener system - virtually zero water flow
    By Qckslvr in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-07-2011, 09:26 PM
  3. Master Water Conditioning Corp Well Water FILTERING System
    By JohnnyTuinals in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-19-2011, 09:06 AM
  4. Water Tank Setup - 1-Tank System vs. 2-Tank System vs Tankless
    By Furnace in forum Water Heater Forum, Tanks
    Last Post: 04-27-2011, 06:22 AM
  5. Rural Water System: System Water Main, Meter Reading Overcharging, Leak Detection
    By Goldpenbkkpr in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-28-2011, 06:01 AM
