Results 1 to 3 of 3
Thread: How to figure cost of pumping one gallon of water
    Dec 2009
    northfork, california
    Default How to figure cost of pumping one gallon of water
    We share a well. The primary guy pays the electric bill and we meter my renters water at that house by the gallon. Its been zero for years as I have another well on the rental land that recently started pumping nasty clay, and finally the pump inlet [I am guessing] is clogged.
    I originally drilled the well and built his house, so I know its 220' deep and makes endless water of bottled quality. 1 HP pump, unknown standing water level.
    Would several fills of a 5 gallon bucket with a stopwatch and ammeter clamped on the feed wires give enough numbers to juggle and then divide into the KW cost?
    How would YOU do it?
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    At 10 cents per KW, a 1 HP will burn 10 cents per hour, $2.40 per 24 hour day. At 10 GPM that would be 17 cents per thousand gallons.
    Dec 2009
    Bet that makes the guy in the city wish he had a well.
  1. Ruud40 gallon Gas Hot Water Heater
    By jarge40 in forum Water Heater Forum, Tanks
    Last Post: 02-12-2012, 05:43 PM
  2. 50 or 55 gallon water heater cost ??
    By ballvalve in forum Water Heater Forum, Tanks
    Last Post: 01-15-2011, 11:41 AM
  3. Need the very best in 80 gallon water heaters
    By MOVIE GUY in forum Water Heater Forum, Tanks
    Last Post: 01-18-2010, 12:45 AM
  4. Cannot figure out how to adjust tank water level
    By watertight in forum Toilet Forum discussions
    Last Post: 11-08-2007, 04:20 AM
  5. Trying to figure out what is causing water hammer?
    By jmichaelyoung in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-28-2005, 09:59 AM
