Thread: Sediment filter questions
    DIY Junior Member
    Feb 2008
    Hudson Valley, NY
    Default Sediment filter questions
    Hello all,
    I'm (finally) going to be replacing my whole water system due to a number of problems ( piping hanging in mid air, poor pressure on 2nd floor, tank bladder has a small leak, tank and piping directly in front of elect panel, 40 yr old softener ) and I'm starting on the sediment filters and figured I'd ask for some comments/advice. I currently have a 20" x 3" filter that takes 2 coupled together 'regular' filters. They gets filled pretty fast and really cut my water pressure, so I want to :
    - Use 1 1/4" PVC ASAP water comes through the check-valve from the well.
    - Add a Cycle Stop Valve (right after the check valve, before pressure tank) for constant pressure
    - Use 2 filters (after pressure tank, before softener) w/1" connections in parallel, so that while changing one, the house can run off the other.
    - For the filters I'm thinking either (2) 20" x 3", or (2) 10" x 5" Big Blue. Is either better than the other?
    - I thought I'd like at least 1 clear filter housing, just to see how it looks before changing them, but they are way more expensive. Is a clear one worth getting?
    - I like the idea of the pleated 'washable' filters to cut costs ( clean them every few months and replace every (1,2,3?) yrs. )
    - Given my slightly acidic, high iron and sediment water, I want to use PVC as much as possible (the water ate thru the previous galvanized pipe). The ball valves/unions are much cheaper too, but can they be trusted to last as long or longer than brass?
    So, does this sound like a good plan?
    Thanks for your input
    CJ
    If you get rid of all the galvanized you probably will not have a need for any type/size disposable cartridge filters. And your new softener will last longer.
    PVC can't corrode like brass does. And I used to buy and use PVC valves by the case and never had any problems with them. CPVC valves were a different story.
    Nov 2010
    Maine
    You can't use PVC for water piping within a residence
  1. Use Chlorine (Charcoal) filter in Whole House Sediment Filter Housing ??
    By kstuart in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2011, 02:04 PM
  2. Sediment Filter 2
    By Catmaster100 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-15-2008, 09:35 AM
  3. Sediment Filter Location and more
    By yar02169 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-14-2007, 04:08 PM
  4. Which is best whole house sediment filter?
    By rosenb in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-15-2006, 07:50 PM
  5. Whole house sediment filter?
    By Vitaliy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-20-2005, 08:50 AM
