Results 1 to 2 of 2
Thread: When you have a beveled metal washer intergrated into a faucet supply hose.....
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default When you have a beveled metal washer intergrated into a faucet supply hose.....
    When you have a beveled metal washer integrated into a faucet supply hose.....is that considered a one time tighten.
    Hooking up a Grohe faucet and noticed the metal bevel washer on the supply hose built into it.
    Let's pretend a angle stop goes bad and you replace that.
    When you remove/reinstall the exisiting faucet supply hose, 9 times out of 10, will it still seat and Seal or will it leak ?
    Just wondering....
    Plumber jimbo's Avatar
    Not necessarily. If overtightened on first install, the bevel may be damaged to where it won't reseat./
  1. How to install a metal hose bib when you have PVC piping???
    By Flipperman2a2w in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-14-2011, 08:37 PM
  2. O-ring supply connections on lavatory faucet -- convert from braided hose to 3/8 tube
    By dujour in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2010, 08:05 AM
  3. Washer hose leak, how often do you change hoses?
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-28-2009, 03:28 AM
  4. sealing a flexible metal water supply to toilet
    By bdt in forum Toilet Forum discussions
    Last Post: 06-13-2007, 09:07 AM
  5. beveled vs flat washer
    By bbillcee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-23-2007, 01:39 PM
