Thread: Removing 4" cast iron waste line
    DIY Junior Member Origen's Avatar
    Aug 2012
    Chicagoland
    Default Removing 4" cast iron waste line
    I have a 4' section of horizontal 4" cast iron soil pipe in a ceiling I need to remove/replace. It is full of waste. When I removed the ceiling I was bathed in human waste, and I would like to avoid that experience a second time! What would be the best way to drain it before cutting it out? Should I cut a slot with a grinder and place the bucket underneath? Drill it? Any help would be greatly appreciated.
    Aug 2009
    South*East
    Why not snake the line to allow it to drain?
    John
    How is it connected? If with No-Hub couplings, loosen one end, put a barrel under that end, then lower it so the water runs into the barrel.
    Care to share ,why it's full of waste ?
  1. When connecting 4" ABS sewer line to Cast Iron, how deep is deep enough?
    By Man in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-08-2012, 08:16 PM
  2. Removing Lead/Oakum from cast iron - replacing tub/sink drain line - pics
    By renstyle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-10-2012, 03:09 PM
  3. Removing Cast Iron Drain
    By jim.gary in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2009, 05:59 PM
  4. removing 4'' cast iron stack
    By tk2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2006, 06:12 PM
  5. Cast iron waste pipe
    By cz639 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2004, 07:20 PM
