Unless you told them your static water level, that's how far down to the surface of the water in your well, they or no one else can tell you how much water is in your 6" well (1.47 gal/ft of water); unless they incorrectly assume it is full of water. Your usable water is from the static water level to the pump inlet. But... my experience in shocking 6" wells (and your ongoing problem) says you need more than the gallon you've been using.
Good idea and, yes, bacteria would be killed at 140f or higher if exposed to it for an hour or so. H2S would not be affected. An actual measurement of the temp of the water is the only way to know if you get to 140f or higher.
You seem to imply I shouldn't use carbon, or that carbon should only be used in conjunction with chlorine? That makes sense if there is a bacteria problem, and I will test for bacteria if I go that route to make sure there are none. Maybe another issue is that with well water you cannot completely kill off all the bacteria as they could be in the aquifer itself? I don't know the answer to that question.
