Page 1 of 5 12345 LastLast
Results 1 to 15 of 73
Thread: Iron staining, Sulfur smell, water options
    DIY Junior Member astraelraen's Avatar
    Aug 2012
    ID
    Default Iron staining, Sulfur smell, water options
    I posted this on another forum, but I decided to pose the question here too as I have read a few good articles from here.
    We have well water and had the Kinetico guy come out today to chat with us about our water. Culligan is coming out Wednesday to give us a proposal.
    Here are the stats given by Kinetico.
    5.5 gpg hardness
    141 TDS
    .5 ppm iron
    6.9 PH
    Sulfur is 1-2ppm (this was a guestimate based on smell, I don't believe he tested for sulfur?)
    We have a sulfur smell in the hot and cold water, but it is much worse in the hot water.
    There is no slime or buildup in the toilet reservoir, so he doesn't think there is a sulfur or iron bacteria problem.
    He suggested a 2030S with K5 RO system at the sink + 20" carbon filter to try to remove the sulfur odor. This was a little over 4k installed with labor/tax.
    We really don't care for softened water. We get iron staining over time and the sulfur smell has to go. Those are the two objectives we are looking for. I have traditionally chlorinated the well every 6 months or so and the smell is drastically reduced for a certain amount of time afterwards.
    Is there a better or cheaper solution to mainly removing the iron and sulfur?
    Are there sulfur and/or iron filters that do not soften the water and actually work?
    It seems to me that if you start softening your water you have to add RO, etc on top of it to get back to drinkable water. The K5's price was fairly ridiculous in my opinion.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by astraelraen View Post
    There is no truth to that myth.
    Iron filters don't soften water.
    DIY Member bcpumpguy's Avatar
    Jul 2012
    Langley BC
    you need to find out what is actually making the water smell that way, could be manganese, h2s, sulfur. But if you don't want to soften the water a catalytic carbon might do well for you.
    Great choice in not going with Kinetico.
    A softener when needed costs less and prevents premature replacement of fixtures, water heaters and other water using appliances and clothes washed in hard water.
    Not all iron filters can remove H2S/sulfur, nor can all H2S filter type equipment remove iron.
    Shocking a well can create carcinogens.... eat metal well casing, ruin pumps and electrical cable... or cause hard to treat water quality problems.
    If shocking got rid of the odor, then that means the odor is caused by bacteria and.or naturally occurring H2S gas in the well water
    When you shock a well you must sanitize/disinfect the plumbing and fixtures in the house.
    You don't want to use carbon if there is any type of bacteria in the water.
    Manganese does not cause odor problems.
    Softening water adds 7.85 mg per liter (roughly a quart) of sodium per grain per gallon of compensated hardness removed.
    Without doing the math, in your case that probably would be less than the sodium in a slice of white bread. And much less than an 8 oz glass of milk, etc. etc..
    DIY Junior Member Bobby Jordan's Avatar
    Aug 2012
    Idaho
    It sounds like I need to have the water tested for iron and sulfur bacteria then to know for sure if there is a bacteriological problem?
    Another reason we are hesitant to go with a softener is that we have an "advanced" septic system that requires annual monitoring by the state. The company that installed our septic said that the manufacturer does not recommend water softeners. They stated that per the manufacturer it could eventually mess up the specific gravity of the water in the septic over time and cause problems. They also mentioned that excessive backwashing could cause problems with water flow in the septic unit (although I guess this could be an issue with any water filtration device.) The company did not say specifically that adding a softener would cause problems, but if our annual testing comes back out of specifications we would have to potentially remove any water filtration devices we have setup and/or switch to other solutions.
    I'm not completely against a water softener, but we aren't willing to buy a water softener if:
    a) it's not really going to fix the problem and
    b) we will still have to buy expensive RO systems, etc to make the water actually taste good again. The only experience we really have with softened water are most hotel systems and I'm not sure there is a single hotel I can remember thinking that the water tasted anywhere near good.
    What about MangOx, Terminox, Pyrolox, Filox type filters? They all seem like they are generally the same type of filter to an uneducated person like myself? From internet research these types of filters seem like they are the holy grail of iron/manganese/sulfur problems.
    Ideally, just going on my uneducated internet research, I think I would like a 10/20" sediment type filter, then a single unit to filter iron/whatever, then a carbon filter if necessary for smells?
    I admit, I'm probably looking for "too simple" of a solution to multiple water problems and I'm certainly open to being educated
    Quote Originally Posted by Bobby Jordan View Post
    IRB creates a clear to black snotty slippery slime in toilets tanks from the water line down. that's unless you use some type toilet tank cleaner.
    You need to check with the manufacturer. If you have the type that chlorinates the water and sprays it on the ground, I've heard the manufacturer is afraid of the sprinkler heads clogging up with scale. That's a bit strange when they have no limit on how hard your water can be. hard water causes scale build up and especially where the velocity of the water is increased, like the hole in a sprinkler head. High TDS content does the same.
    As to the volume of water... they don't limit the type of tub, or how many gallons can be drained out of a tub or dish or clothes washers, which is a higher GPM than your softener will have. And that flow from a softener is flow controlled to usually like 1.5 gpm to say 5 gpm, and that would be a fairly large softener. Backwashed or regenerated filters have a higher gpm low rate.
    Softeners don't remove bacteria or H2S. No filter removes hardness. So far you've not shown and need for an RO and removal of hardness, iron and any manganese usually improves the taste of the water. Hotels chlorinate their water, if you have to chlorinate yours, you will also be removing the chlorine.
    BTW, it is what is in water that gives it a good or bad taste and good water, it has no taste. So my suggestion is to get whatever equipment that is needed (you do need a softener) and use the water for a month and then see what you think of the taste and go from there.
    Aug 2012
    Idaho
    We have no "slime" or clumping in the toilet tank and do not have any chlorination or toilet tank cleaner that we use regularly in the toilet tank. The Kinetico rep did mention that the toilet tank water appeared to have an "oily" sheen or film to the top of the water that was broken and repelled if you touched the water, it does not have any noticeable odors. He indicated this could be some sort of a bacteriological problem, but he did not seem to provide a solution that would solve bacteria.
    You are correct, they don't set a specific volume limit, it's more of a "hey, don't use too much" because you could overload the system. I'm not sure exactly how it works but its based on contact time so if you end up overloading the septic it will end up dumping the "untreated" or "not completely treated" stuff out of the tank.
    We will discuss a water softener again and potentially try that without an RO for now.
    I've seen plenty of information on the internet saying a water softener should never be used as an iron filter and vice versa. With .5ppm iron do you see us being able to use a water softener as an iron filter and water softener unit? The Kinetico rep seemed to think it was possible using "iron salt" or whatever he called it.
    Assuming we don't have bacteria problems, could a 20" carbon filter after the softener potentially solve the sulfur smell? Or do we need a dedicated iron/sulfur filter, whether that be chlorination or some other method of filtration.
    Feb 2011
    NW Ontario, Canada
    The Kinetico rep did mention that the toilet tank water appeared to have an "oily" sheen or film to the top of the water that was broken and repelled if you touched the water...
    That pretty much describes my untreated water but my water does also have a noticable odor when first exposed to air. The smell does dissipate quickly.
    My iron filter aerates the water with a micronizer and I find that clears up most of the odor. After it has gone through the iron filter there is no more odor. If I had my druthers, I would go with an iron filter that aerates with a compressor rather than a passive micronizer. I use a softener after the iron filter and a RO for drinking/cooking water.
    As for a load on a septic system, I don't discharge the backwash to the septic. Regulation will vary by location but here we are allowed to treat it like grey water so mine goes the same place as my sump water.
    The sheen is a sign of.... old guy memory here.... manganese reducing bacteria? Anyway, you treat it the same as any other reducing bacteria, you kill it with a disinfectant.
    You might want to have a Coliform bacteria test done.
    A softener may use up to 50 gallons of water per regeneration but... the water flow is controlled in gpm and it takes up to an hour and a half to put it all in the septic. That's much slower than a tub bath or the dish and clothes washers, The washers have a 1" drain line and the softener is about half that.
    Softeners don't filter ferrous iron, they ion exchange the positive charged iron ions the same as they do hardness (calcium and magnesium), manganese, copper etc.. And it works very well. Guys that don't support using a softener for iron removal sell iron filters, in addition to the softener. So what does tell you?
    A disposable cartridge filter is not a good choice, plus you need a disinfectant or to shock the well correctly periodically.
    Correctly is to add bleach to the well by mixing it in 5 gallon buckets of water at about a half gallon per 100' of water in the well. As you pour it down the well, you run a garden hose to rinse it down. When you get all the bleach added, then push the end of the hoise down the well with it running full bore until it will stay in the well on it's own.
    You leave it run for like 20 minutes and shut it off.
    Then using a wide mouth glass or jar to hang your nose on the rim of you smell deeply for chlorine at faucets after getting a strong smell of bleach. Start at the boiler drain valve at the pressure tank. Then run water to all cold water faucets starting at the kitchen sink, one at a time.
    When the cold is done at the kitchen sink, run the hot for a minute and shut it off.
    Do the bathroom sink cold and when done tun the cold at the tub on for 10 seconds and shut it off. Then flush the toilet on the way to the next bathroom doing the same until all the bathrooms are done. Then start the clothes washer on cold/cold and let it fill for a minute and stop it.
    Turn on each outside faucet for like 20 seconds one at a time and shut it off.
    BTW, no water use from the time you poured the bleach down the well until a couple hours later.
    Then every 15-20 minutes run the cold water at each inside faucet for 10-15 seconds and turn it off. You don't have to run the tubs and don't flush the toilets, inside cold faucets only. Repeat that process at least 6-8 times.
    When finished, run the hose at like half flow where chlorinated water won't kill/stain things and you can see/watch the water flow (from the house) and watch the flow doesn't decrease. If it does decrease the flow until it doesn't.
    You do not want to run the well/pump dry. After like an hour +/-, shut it off and run all cold water faucets in the house and flush toilets and put the clothes washer in Rinse for a minute and then Spin. Run the outside faucets for a minute.
    You may still have bleach in the water and you should protect your eyes and clothes until it is gone, that could be days and you can run the hose some if the bleach is real strong but always watch the flow so you don't run too much water.
    Aug 2012
    Idaho
    The well is 2 years old. There were no coliforms when it was dug. I did an "at home" coliform test earlier this year which came back negative.
    I'm thinking about just having a lab do a coliform/iron bacteria/sulfur bacteria/whatever other bacteria test to get a concrete yes or no on bacteria issues.
    If there are no bacteria issues it seems like i could get away without a chlorinator, otherwise it seems like i will need one of those as well.
    Thanks for your suggestions Gary.
    DIY Senior Member F6Hawk's Avatar
    Mar 2012
    Alaska
    Gary, half a gallon of bleach per 100' of well? Are you SERIOUSLY giving out this advice on a public forum, with no other guidance? I sincerely hope no one pays you any attention, without doing some research themselves. Your advice does not take into account the diameter of a well, therefore no accounting for how many gallons of water, and of course no thought is given to PPM of bleach. How about you give some specific numbers before you cause an innocent viewer to damage something?
    The numbers you gave would be about right for a 6" well, but it would be shy of the 200 PPM mark typically used in sanitizing. 4.41 pints for a 100' deep 6" well would actually be closer to the mark.
    For anyone reading this who wants to sanitize their well, I suggest reading this: http://msucares.com/pubs/publications/p1865.htm or other sources which set forth correct amounts of chlorine to use for disinfecting your well.
    Nov 2010
    Maine
    Every plumbing code has the PROPER method of chlorinating within their pages.
    Aug 2012
    Idaho
    Quote Originally Posted by F6Hawk View Post
    Per this website I should use about 2.25 gallons of bleach in my well to chlorinate it. I have traditionally used ~1 gallon. This could be part of the reason why I can never get rid of some of my problems, if in fact it is a bacteriological problem.
    Our well is 380 feet deep, 6" casing. That website says I have 559 gallons of water. I need about 18 pints, or 288 ounces of bleach. Which is right at 2.25 gallons.
    I may try that this weekend to see what the long term effect is, since in all my previous attempts to chlorinate the well I have either used a pool chlorine tab or 1 gallon of bleach.
    I turned my water heater up to 150F last night for 10 hours to see if it would remove the sulfur smell, from internet research, if it is bacteriological that should kill the bacteria and greatly reduce the smell? I let the hot water run for awhile this morning before my shower and I'm not sure the smell decreased at all. Is this further indication it may just be a sulfur gas problem rather than a bacteria problem?
    Thanks for all your help. I'm beginning to hate water!
    Feb 2011
    NW Ontario, Canada
    One method prescribed for recurring well bacteria, is to "overload" the well. It involves pumping about 500 gallons into a storage tank, then chlorinate both the water in the storage tank and the well before pumping it back into the well. The idea is that the bacteria may get established in the aquifer and simply chlorinating the water in the well will not reach far enough into the aquifer.
    Bacteria can also get established in the plastic supply lines in the home. The usual symptom of that is a strong smell when the tap is first turned on after not having used it for a while but then diminishes.
    DIY Member mariner's Avatar
    Sep 2005
    Hixon, BC
    I have just been reading this thread and thought I might make a comment.
    I too, am on a well which is 350 ft deep. The well was already installed when I bought this proerty seven years ago (older home about 1965'ish). I have both water filters and a water softener.
    My cold water smells yet my hot water does not smell. The hoses to the washing machine show a marked difference - the hot water hose inlet is clean and stain free. The cold water hose inlet has rust stains and the water smells.
    I am thinking that in my situation has the water temperature affecting the outcome.
    My system has two water filters - 5 micron before the water softener and 1 micron filter after the softener. The water tastes great and there is no staining of the laundry.
    Of the two bathrooms I have, one toilet has mineral deposits inside the bowl (only five years old) and the other toilet has none and is over twenty years old. I think the toilet bowl staining has something to do with the porcelain glazed surface, other wise both toilet bowls should have the mineral staining/deposits.
    I know this doesn't directly relate to the original post, but there are similarities and therefore, should be of interest.
    mariner
  1. Help Deciding Best Way to Get Rid of Sulfur Smell. Iron filter or Chlorine? Other?
    By carfan87 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-17-2011, 06:12 AM
  2. Too much staining from iron in well water
    By Golfsupttdd in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-03-2008, 08:16 AM
  3. Sewer/Sulfur Smell From Isolated Shower - City Water
    By kucharskimb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-29-2008, 04:15 PM
  4. New water heater:strong sulfur smell
    By coffyguy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2008, 02:26 PM
  5. Can Sulfur smell and iron be removed with a softner
    By Texaro in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2007, 07:40 PM
