Results 1 to 3 of 3
Thread: 3 way timer switch
    Default 3 way timer switch
    I am trying to add a digital timer switch to a 3 way configuration. I got the switch to work with one issue, it only works if the 1st switch in the circuit is in the on position. Please note that the other switch is a standard on off switch. If I turn the 1st switch off, I cannot turn the lights on from the digital timer. If I have it on, then the timer works perfectly to control the lights. To make matters a little more interesting, I do not have the more common configuration for 3 way switches. I have the configuration in the attached diagram where one switch flows through the second junction box to the lights. The digital timer is in the #2 position in the diagram below.
    Can anyone help me to get this working correctly? Do I just need a second digital switch or am I SOL to get the timer to work with this setup?
    All switches in the circuit must be designed for 3-way circuitry - you can't use a simple on/off switch in a 3-way circuit. The timer you have may or may not be able to work in a 3-way circuit. Without knowing what you have, there's no way to tell you how to make it work.
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    If your wiring at the matches the illustration a digital timer may not work since there is no neutral at either switch location.
  1. 240V Timer Switch
    By K2 in forum Electrical Forum discussion & Blog
    Last Post: 05-21-2012, 07:15 AM
  2. Reliable timer switch for wells?
    By ballvalve in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-27-2010, 03:31 PM
  3. Timer switch for bulb heater blown
    By 98ZJUSMC in forum Electrical Forum discussion & Blog
    Last Post: 06-25-2010, 12:52 PM
  4. New Bathroom Fan Timer Switch
    By draven8795 in forum Electrical Forum discussion & Blog
    Last Post: 04-02-2009, 07:01 AM
  5. Outdoor 3-way switch and timer
    By Hillel in forum Electrical Forum discussion & Blog
    Last Post: 11-20-2007, 11:24 AM
