Results 1 to 2 of 2
Thread: Lowering a Kitchen Sink Drain Line
    DIY Junior Member morpheusmurals's Avatar
    Aug 2012
    Chicago, IL
    Default Lowering a Kitchen Sink Drain Line
    Hello,
    I just installed a 10" undermount sink- used to have a 8" above. Nice surprise when I figured out the drain line was too high.
    I am planning on cutting open the wall to lower the drain in the main line.
    Couple questions:
    Currently the main drain travels 24" horizontally connected with a Tee at the 2" main line. That 2" pipe is vented to the roof. Is that vented correctly?
    Can I just open that line and do the same thing lowering it to the appropriate height? Is the Tee creating a vent? Can I use a Fernco Quick Tee to make the new connection? The line is galvanized pipe.
    Do I need to slop the horizontal line downward toward the main line?
    I attached a photo when the wall was open. Of course now it is all drywalled and has a nice cabinet in front.
    Cut the T out with enough pipe beneath and above to allow for a stub to be glued into a pvc (or abs, whatever is generally used in your area) to a sanitary T (I can never remember if that must be a sanitary T or a wye - since above is a vent, I think a sanitary T is okay), not a t like is there now, and a stub above then use nohub connectors to reattach that new assembly that you cut out. The pipe coming up from below is likely a revent from something below (maybe the laundry or a sink in the basement?). Note that, depending on what's above, once you cut the pipe, it might move. To ensure that doesn't happen, you might want to install a hanger brace.
  1. ...yet another kitchen sink drain line routing question.
    By dirtyhands in forum Plumbing Forum Discussion & Blog
    Last Post: 12-07-2011, 05:13 AM
  2. Replies: 1
    Last Post: 05-25-2011, 05:49 AM
  3. kitchen sink: trying to find off center drain undermount sink
    By belzoid in forum Plumbing Forum Discussion & Blog
    Last Post: 09-29-2010, 06:00 PM
  4. Kitchen Sink Drain Line Through Studs???
    By junky99 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-19-2010, 07:54 AM
  5. Replacing Kitchen Sink Drain Line
    By Leaky1 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-27-2009, 06:56 AM
