Results 1 to 12 of 12
Thread: Posi temp issue with a curveball
    DIY Junior Member boss99er's Avatar
    Aug 2012
    Omaha NE
    Angry Posi temp issue with a curveball thrown in
    Hey guys, I need some help here. I have a shower with a Moen Posi Temp valve. Its installed in a bathtub/shower combo. Lets say for this example I have the handle directly pointed up...right in between hot and cold. If I let the water run out of the faucet, its a nice warm temp with no issues. I can adjust it colder or hotter and the water temp responds as it should. If I pull the diverter and make the water run out the shower head, it gets full hot without moving the handle at all. If I move the handle to colder, there is no response. There also seems to be a change in the sound of the water rushing through the valve. If I push the diverter back down and let it come out of the faucet again, without touching the handle it goes back to being a nice warm temp like it should. When it goes back to warm, I can hear a change in the tone of the water going through the valve again. I figured it was just a faulty cartridge, so I purchased a brand new cartridge and popped it in. No change.
    Any ideas? Thanks in advance!
    Plumber jimbo's Avatar
    I suspect the balancer is unable to fully react to some pressure changes due to the large difference in volume flow between shower and tub. It should, of course, so the first step I would do is is get an inexpensive pressure gauge at the hardware store, connect it to a bibb or faucet on the house side of your regulator, and measuer both static ( no water running) and dynamic ( some faucet full on) pressures. These readings may be informative.
    Aug 2012
    Omaha NE
    Hmm...ok...but what would make this change so suddenly? I can't say for sure, but it seemed to start around the time we put a new wand style shower head on that shower. Neither my wife or I can say for sure that's when it started. Could that cause this issue? When you mentioned volume difference, could the restriction in flow to that shower head cause this? Are posi temp valves sometime incompatible with certain shower heads? I know everything now days is super low flow...
    Aug 2012
    Omaha NE
    I'm going to Lowes over lunch to buy a pressure tester. Since the hydrants on my house are after the meter, they should work for the test, correct? What should the levels be for static and dynamic?
    Also, thanks for the help!!!
    Aug 2012
    Omaha NE
    I should also note this. This morning I was taking my shower and before I was done, I turned the handle to almost full cold. The water stayed full hot. It was tolerable, because I turned my water heater way down so we could at least continue showering until this is fixed. Anyway, I turned it to almost full cold, and the water stayed hot. I pushed the shower diverter down and immediately the water coming out of the faucet was full cold. Its so odd! This has be really baffled!
    Aug 2012
    Omaha NE
    Ok, tested the water pressure at an outside hydrant that I know is on the house side of the regulator and meter and it was 85 static, and about 83 dynamic. That's pretty high right?
    Aug 2012
    Omaha NE
    I decided to test on an actual faucet in both of our bathrooms and static was 85 and dynamic was about 78. Still too high though for the posi temp?
    You're on the edge where code requires a pressure reduction valve (normally 80psi). But, the valve should work at the pressures you have.
    Aug 2012
    Omaha NE
    Well then I'm at a loss for what could be causing this. Looks like its time to call a plumber and see if they can figure it out.
    Aug 2012
    Omaha NE
    Is there something else I should check off the top of your heads?
    i would call moen and see what they have to say.. they have great customer service from my experience. an easy test is try a different shower head, as this seems to be causing your problem...maybe if you have your old one to pop back on and see if it works
    Aug 2012
    Omaha NE
    I'll give them a call today and see what they say. I would try the old one, but we threw it away when we changed to the new one. I knew that was a bad idea! Ha ha. Basically, we replaced a large faced normal shower head with a wand type. I tried removing the restrictor in the wand head to see if that made a difference. No luck there either.
  1. Moen Posi-Temp....almost but not quite
    By das108 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2011, 03:37 PM
  2. Moen Models? Posi-Temp
    By dkdaniel in forum Shower & bathtub Forum & Blog
    Last Post: 01-29-2011, 05:51 PM
  3. Moen Posi-Temp vibration
    By kebisch in forum Shower & bathtub Forum & Blog
    Last Post: 02-11-2007, 11:41 AM
  4. Moen Posi Temp Question
    By BMWMK2 in forum Shower & bathtub Forum & Blog
    Last Post: 02-23-2006, 07:47 AM
  5. Posi-temp faucet
    By psal2 in forum Shower & bathtub Forum & Blog
    Last Post: 10-23-2005, 05:29 PM
