Results 1 to 4 of 4
Thread: sears pump 390.2518 long running time to reach 60PSI
Hybrid View
    DIY Junior Member olaskok's Avatar
    Aug 2012
    California
    Default sears pump 390.2518 long running time to reach 60PSI
    I have a desert house that is using an in ground water tank . the system has a pressure tank and a sears pump 390.2518. The pump does ok but it started taking a long time for the pressure to run from 55 psi to 60 psi. Can I adjust the pressure down to 55 to reduce running time. It seems that the pump is running 4 times longer to reach the 60 psi than it used to. I am not sure on the run time but it has increased. once the pressure is reached and there is no demand on the system the pressure holds. so I do not think there is a leak. I took the cover plate off of the pressure switch and there are two springs and adjstment nuts one larger than the other. I assume that the pump is starting to fail ( impellers?) but replacing it is going to be a job. So I thought I could turn the pressure down in order to reduce the load on the pump. Please help - thanks
    DIY Junior Member IndyBob's Avatar
    Aug 2012
    Indianapolis
    First, remember that there is 120v or 220v that is easily touched. What brand pressure switch is it? If it is Square D, then the larger nut raises and lowers both the cut-in and cut-off at the same time. The smaller nut increases or decreases the gap between the cut-in and cut-out. Loosening the spring on the larger nut (counterclockwise) should lower the pressure. I would avoid the smaller nut unless you want to change the gap. If the smaller nut is too loose, the pump will never turn off because the cut-in and cut-off are too close together.
    Aug 2012
    California
    thank you I only visit the house once a month during the summer 110 degrees. I will follow your suggestion and I post my result THANKS
    Nov 2010
    Maine
    Sounds like either the pump is worn, there is something stuck in the venturi or the line to the pressure switch is plugged up.
  1. Hot water takes long time to reach one faucet, all others ok
    By EdHitchens in forum Water Heater Forum, Tanks
    Last Post: 03-21-2011, 04:34 AM
  2. Pump on Sears shallow well pump runs too long
    By slackattack in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2008, 06:12 AM
  3. Deep well jet pump - runs a long time
    By av8or10 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-13-2008, 02:22 PM
  4. pump taking long time to reach cut off!!
    By Byoung5187 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-01-2006, 06:05 AM
  5. Sears Shallow pump replaced, T on Inlet, pressure over 60PSI
    By educateme in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-05-2006, 02:33 PM
