Results 1 to 4 of 4
Thread: Surround over Plaster walls?
    DIY Junior Member cookc's Avatar
    Aug 2012
    Rochester, NY
    Question Surround over Plaster walls?
    I have a 100+ old house and has an old freestanding cast iron tub that has to go, I would like to replace it with an acrylic tub and surround but was wondering if it would be ok to install it over the exhisting plaster walls as i am not relishing the idea of taking down plaster and lathe. It says to install directly over studs, but most of the surrounds i saw say that, so what do you think? Is there a reason for installing to studs? If i do, is there anything i should do to the walls first before i install?
    Thanks for any help!
    IF you do NOT install it against the studs, etc., you will end up with an installation that looks like a homeowner did it.
    Plumber jimbo's Avatar
    If the surround is labeled "direct to studs" then if you apply it over teh plaster, it will be about 2 to 3 " to big, and over lapt the tub too far. There are other surrounds which glue up to the wall material. You will have to open the wall for the tub. They are 60" unless you get a "special", and therefore go stud-to-stud
    Many of the plastic surrounds have a lip on them that is designed to be hidden by the edge of the wall butting up to the bumpout of the surround and sit on that lip, helping to lock the thing tight to the walls.
  1. tub/shower surround walls - attach directly to studs or install wallboards first?
    By johnny-canuck in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-22-2012, 06:33 AM
  2. Tile surround vs. Shower Walls
    By robb01 in forum Shower & bathtub Forum & Blog
    Last Post: 04-30-2010, 01:08 PM
  3. Sterling Tub Shower surround walls only
    By scri8e in forum Shower & bathtub Forum & Blog
    Last Post: 04-05-2008, 04:42 PM
  4. Problem With Ceramic Tile Shower Surround Walls
    By punkpk in forum Shower & bathtub Forum & Blog
    Last Post: 02-13-2007, 01:40 PM
  5. glue on plaster walls four feet up ...
    By tameria11 in forum Remodel Forum & Blog
    Last Post: 09-28-2005, 09:48 PM
