yooper69
I have a 20 gal. Amtrol Baron Group BN4202 pressure tank that has failed after 9 years (installed in new house built in 2003). Our well pump has been short cycling more and more, and the last few weeks it's gotten worse. It will kick on and off twice during a toilet flush. The tank also makes almost a dripping sound as it is filled by the pump.
Last night I drained the tank and it has 0 psi when empty. While putting air in the valve to push the remaining water the bottom couple gallons or so was very rusty, and once the water was out it was spitting air. This leads me to believe that the bladder is shot. I did pump it up to 38 psi before I refilled it, and it seems to have stopped the short cycling for now, but on the flip side we are now getting a bit of air sputtering in the upstairs faucets.
I can get a replacement 40 gal. Amtrol from the well driller that did the initial install at a 10% discount due to it failing "quicker than most" but his price is still quite a bit higher than I can get an Amtrol wx-250 for. I'm capable of doing the install myself, and he wasn't adding anything for labor. So here is my dilemma - is the Baron version of the Amtrol lower quality than the Well-X-Trol series? I'm mulling the wx-250, and a Flexcon FL-17. Given the fact the Baron failed fairly quickly, and the fact it is surprisingly rusty on the outside (well water is about 50° during the summer so a lot of sweating), I'm conflicted with my experience with Amtrol vs. what I've been reading online about them. The cost of the two tanks I'm considering is about the same, so I'm more interested in getting a tank that will last.
Any advice is greatly appreciated. I'm looking to order the tank by Monday at the latest.
Thanks.
Thanks.
