Results 1 to 3 of 3
Thread: Best angle stop for cpvc
    DIY Junior Member Plummer's Avatar
    Aug 2012
    Michigan
    Default Best angle stop for cpvc
    What is the most reliable stop I can use for cpvc. Price not being a concern I don't want use anything cheap. Not going to lie cpvc scares me and it's the first time I used it. Thanks!
    Assuming you're using a compression stop, whatever you like for copper should perform the same.
    IF I were using CPVC, and I would not, I would still install it with copper stubs for the stops. This would be so that the stubs COULD NOT break off over time. But since it is already done, any compression stop for copper will work on CPVC, usually with a support sleeve inserted into the tubing first.
  1. Stopped By An Angle Stop -- So What Went Wrong?
    By RedClay in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-24-2011, 06:49 AM
  2. Altman's angle stop valves
    By bobbobwhite in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-17-2008, 01:41 PM
  3. wet angle stop
    By rg21 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-04-2007, 06:59 PM
  4. Installing an angle stop valve
    By PAV in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-28-2007, 02:13 PM
  5. 1/2' compression angle stop on cpvc?
    By Racer814 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-11-2007, 07:41 AM
