Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: New Shower Valve
    DIY Junior Member tommy7's Avatar
    Aug 2012
    maryland
    Default New Shower Valve
    Hey all. Thanks ahead of time for the help!
    I am trying to install a new shower valve and have had my difficulties.
    With each difficulty I have learned much, and now feel capable of doing the job. ( yea..right.)
    This was a new Moen shower valve a week agao. I have sweated and unsweated pipes a couple times.
    Now, that i am preparing to do it one final time (see "yea right" above).
    I have a couple questions...
    1. How well do i have to clean this valve?
    2. Can I have a corner so close to the valve? If so, do I sweat it on one step or two? Would I be better off putting an elbow in lower and allowing my self more room by the valve?
    A little Emory cloth to clean things up, then flux and solder it with no-lead solder.
    As long as the cartridge is out while soldering, it doesn't' matter how close the fittings are.
    Aug 2012
    maryland
    Thanks Terry!
    Actually, it's this close together. If I put flux on both ends and run the solder down the middle, can I count on it sealing both?
    If there is a better way to do it, I'm game!
    You can also use a street 90 into the valve. What you have is doable too.
    The brass body needs to be hot enough to melt and pull the solder in. You can tap the solder onto the body to check your heating progress.
    Because the valve body is much more massive than the elbow, you'll need to apply the heat to the valve body more than the elbow, but you probably want them both to be hot enough to solder both at once. Don't overheat the elbow and not get the valve body hot enough - you need the solder to flow into both fittings.
    Aug 2012
    maryland
    Thank guys! It aint pretty, but it soaked up a lot of solder.
    Last question. I want to plug up the elbow shower head joint so i can test it tomoorw. Do I just find a screw that fits it? Whats the common practice? I couldnt get any help at HD.
    The shower arm is standard 1/2" pipe threads.
    A 1/2" x 6" nipple with cap will do.
    Aug 2012
    maryland
    Well, I couldn't wait and tested the pipes tonight. The joint you guys helped me with worked out great! Thanks!
    But, I do have a trickle leak at the bottom of this coupling joint. Doesnt look liek it but I swear I sodered it!
    I'm pretty sure this is a dumb questions, but I do have to remove the joint completly by resweating, then re-clean, re-flux, re-sweat? Thanks!
    Once water gets into a joint...the only way to fix it is to disconnect it, clean and redo. You can reuse the fitting. Hopefully, you can get it apart without having to cut things which would likely mean adding another repair coupling to restore the cut.
    Plumber jimbo's Avatar
    Those globs of solder tell the tale.....not hot enough. Either the fitting was not hot and/or you melted the solder with the flame. The solder MUST melt by touching to hot metal.
    Aug 2012
    maryland
    Thanks! I've learned a lot in the last 2 days! I should have come here sooner.
    A couple more questions:
    1. You said "once water gets into a joint", does that mean if I hadn't tested it with water yet, I can go back and add solder to a joint after it has cooled?
    2. When I re-clean a pipe and joint after pulling it apart, am I trying to get all the solder off so I see only copper?
    Aug 2012
    maryland
    I couldn't remove the coupling by itself, so I removed the elbow above it also. Is it likely that I have damaged my successful joints near it? see picture.
    You do not need to remove solder down to bare copper. Wipe with a dry rag to remove excess, so it will fit into the socket.
    If you reheat the joint, swab some flux on it as well.
    Aug 2012
    maryland
    Is there a trick to these couplings?
    I put new one on. I heated it up thoroughly. It took a lot of solder across the top and bottom. When I wiped it with a rag, it seemed to remove the solder, but i figured it was sucked in, i had used so much . When I tested it, it leaks! Dribbles! All my corners hold great!
    What could I be doing wrong?
    Aug 2012
    maryland
    One more thing that has me confused. The leak is on the left, hot water side. Why does it leak when I turn on the hot or cold water? Granted, it leaks a lot faster when the hot water is turned on. But, aren't they completly separated?
  1. Shower Valve Help
    By destinsb in forum Shower & bathtub Forum & Blog
    Last Post: 12-19-2010, 06:09 AM
  2. Replace shower Plumbing Valve assembly shower head 2 knobs
    By scri8e in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2006, 10:24 AM
  3. Need to replace Shower mixing valve with separate cutoff valve for inputs.
    By OfficeLinebacker in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2006, 09:06 AM
  4. Shower valve with separate diverter valve question
    By remodelingit in forum Shower & bathtub Forum & Blog
    Last Post: 04-28-2006, 01:15 PM
  5. Which Shower Valve???
    By cher394 in forum Shower & bathtub Forum & Blog
    Last Post: 04-28-2006, 09:49 AM
